Esse webinar apresenta um novo e avançado fluxo de trabalho para integração de dados em 3D usando uma abordagem denominada Play Fairway Analysis, que usa vários conjuntos de dados de subsuperfície, de geologia a geofísica e dados de poços. Nele, você aprende a combinar conjuntos de dados em um único modelo calculado que destaca as áreas mais promissoras para sondagem.
This webinar introduces a new and modern workflow for 3D data integration using a Play Fairway Analysis (PFA) approach. While PFA is used in the hydrocarbon industry regularly to mitigate exploration risk from regional to prospect scale, it is only recently being applied to geothermal examples around the world.
We will take you through using various sub-surface datasets from geology to geophysics and well data, to combine them into a single calculated model that highlights the most promising areas for drilling.
While this is a technical webinar and the technical aspect is advanced, you do not not require any prior knowledge of Leapfrog Energy or Edge (our add on geostatistical tool). A background in geothermal resource exploration and concepts of geomodelling will be useful to take the most away.
Overview
Palestrantes
Clare Baxter,
Customer Solutions Specialist – Energy
Andrew McMahon,
Regional Segment Manager – Energy
Bastien Poux,
Director Aetna Geothermal
Duração
1 hora e 30 minutos
