Water resources management: Smart workflows, deep insights
Connected, interoperable software for dynamic analysis of complex water resources
Talk to us
Protect communities, ecosystems and industry through reliable management of complex water systems
To succeed with ambitious engineering projects, protect valuable water assets, ensure water security for communities, and safely manage critical resources, geoscience and engineering teams need an in-depth understanding of surface and groundwater interactions.
But it is difficult to interpret and communicate complex conditions without a common understanding across, teams and disciplines.
Now you can easily create that shared understanding with solutions that integrate data feeds and generate updated models for visualisation and analysis.
Support the big picture with the right tools
It is a huge responsibility to ensure that water management practices protect the communities and ecosystems that intersect with a project. To do this effectively, you need to have workflows and dataflows that are controlled and reliable. We can provide the tools, so you can draw insights from every drop of data.
Central Staged Approval Process
Combine data sources for a comprehensive view
Connect all data, historical and dynamic, hydrogeological and engineering, in one single source of truth that is centrally managed and accessible to teams, managers, and auditors. Add interoperable functions to speed up analysis, share interactive 3D visual models for communicating with stakeholders, and collaborating effectively to make better decisions.
Data plus workflows equals project success
Data is behind all project decisions and is an integral factor in regulatory reviews, standards compliance and due diligence. But workflows are the driver of collaboration and cooperation between teams and across disciplines. Design integrated workflows that support seamless data sharing and communication to unite teams for project success.
“WRD has enhanced support for its robust network of groundwater monitoring wells by offering real-time data from Seequent Central and visual data from Leapfrog Works to geologists in the field, state and national regulators, and stakeholders assisting with contamination sites. Also, being able to show our data in visually engaging ways creates trust and awareness when communicating with the general public.”
Brian PartingtonManager of Hydrogeology, WRD
Ask about tools for Water Resources Management
Talk to us about your project
Seequent's Water Resource Management software
Oasis montaj & Workbench Airborne TEM ModuleGeophysical, Geochemical and Spatial Data Processing and AnalysisSeequent CentralCloud-Hosted Data Management Platform3rd Party AppsOther Data and Applications for WorkflowLeapfrogGeological Modelling and Geostatistical ExtensionsWater UsersOwnership & responsibilityResource Management TeamGeoscientific data analysis & decisionsConsultants, Resource ManagerTechnical sign off & due diligenceInvestors, Communities & OthersDue diligence, transparency, openness, communicationLeapfrog Hydrogeology Extension     Hydrogeological ModelRegulatory OversightIndependent reviewDECISIONS DATA DIGITAL TWIN COMMUNICATION / COLLABORATION ANALYSIS
Stories about water: Successes, challenges and risks.
Mississippi-groundwater-map
Mollusks, levies, and earthquakes: A map of Mississippi’s aquifers answers unexpected questions
One of the largest groundwater surveys in the USA is also answering unexpected questions about ...
Denmark geophysics groundwater helicopter
Mapping Denmark’s groundwater from the sky
Denmark’s groundwater is so clean, you can almost drink it straight out of the ground ...
Connecting to water above and below: Using Leapfrog Works to communicate complex surface and groundwater interactions
Water purveyors are responsible for ensuring that water management practices protect the communities and ecosystems ...
3D modelling helps district in Nebraska get a better handle on water quality
A district in Nebraska is using 3D models generated from airborne electromagnetic (AEM) survey results ...
Seequent software for water management includes:
Seequent Central
Manage, track, and collaborate on geoscience data in a single, accessible environment.
Leapfrog Works
Communicate insights with dynamic 3D modelling designed for civil & environmental projects.
Leapfrog Contaminants extension
Accessible, best practise plume modelling for geoscientists and stakeholders within Leapfrog Works.
Oasis montaj
Visualise, analyse, and integrate all your geoscience data in interactive 2D and 3D models.
AGS Workbench
Tailor and refine every step of your EM, ERT, or IP workflow from raw data to final geophysical models, and present results confidently.
SPIA
TEM and DC/IP VES data processing and inversion.
Res2DInv and Res3DInv
See results fast – easily process and invert your Resistivity and Induced Polarization data in two clicks.
