Res2DInv and Res3DInv
2D and 3D resistivity and IP software for subsurface modelling
Build reliable subsurface models from resistivity and IP data dots
Res2DInv and Res3DInv help geoscientists quickly turn resistivity and induced polarisation (IP) survey data into reliable 2D and 3D subsurface models.
Built for near-surface investigations, the software supports a wide range of survey configurations—including boreholes, water bodies, and time-lapse monitoring—and delivers fast, reliable inversions using smooth, sharp, or constrained methods.
With a streamlined workflow and integration across the Seequent ecosystem, Res2DInv and Res3DInv make it easier to interpret complex geophysical data and share results with confidence.
A screenshot of Seequent's AGS Res2DInv 5.0 user interface
Key benefits
Create reliable subsurface models from resistivity and IP data
Get fast, reliable inversion results
Run smooth, sharp, or constrained inversions using advanced algorithms designed for speed and reliability—even on large datasets.
Icon -Geological Modelling
Work with any survey setup
Support for topography, boreholes, water bodies, and streamed electrodes helps you model complex environments with confidence.
Icon -Modelling and Visualisation
Visualise and compare models with ease
Explore 2D sections and 3D volumes, compare multiple inversions side by side, and export to Workbench, Oasis montaj, or 3D visualisation tools.
Monitor change over time
Use time-lapse inversions to track subsurface changes in groundwater, permafrost, or geotechnical conditions.
Integrate with your geophysics workflow
Import data from a wide range of instruments and formats and export results to Seequent and third-party tools for interpretation and reporting.
Guide inversion outcomes with geological constraints
Apply smooth, sharp, or constrained inversion types to reflect expected subsurface structures and improve model interpretability.
topographic vector
Product Information
Explore Res2DInv and Res3DInv product plans
A screenshot of A Data Profile in Seequent's AGS Res2DInv 5.0 3D Viewer
Res2DInv
Res2DInv is designed for processing and interperting 2D electrical resistivity tomography (ERT) and induced polarisation (IP) data. It supports a wide range of survey configurations, including topography and boreholes, and provides tools for filtering, inversion, and visualisation. With live pseudosection updates and 2D time-lapse capabilities, Res2DInv is well suited for groundwater, environmental, and geotechnical investigations.
Request a demo
This bundle includes all the features of Res2DInv, plus full 3D inversion and visualisation capabilities. It supports true 3D datasets and combined 2D survey lines, with options for time-lapse inversion, vector array datasets, and large mesh handling. Designed for complex subsurface investigations, it is ideal for mining, infrastructure, and environmental monitoring projects that require detailed 3D modelling.
Request a demo
Feature comparison
Compare Res2DInv and Res3DInv plans
Res2DInv
Features
Inversion type
2D ERT and IP
2D and 3D ERT and IP
Time-lapse inversion
2D only
2D and 3D
Survey configurations
Surface, topography, borehole
Surface, topography, borehole, water bodies, streamed electrodes
Inversion methods
Smooth, sharp, constrained
Live pseudosection updates
checked
checked
Model comparison tools
checked
checked
3D visualisation
Viewer only
Full 3D model visualisation
Mesh size
Up to 1.6 million nodes
Up to ~10 million nodes (with 128 GB RAM)
RAM support
Up to 8 GB
Up to 256 GB
Vector array datasets
Not supported
Supported (e.g. IRIS Full Waver)
Export formats
Workbench, Oasis montaj, 3D visualisation tools
Use case fit
Groundwater, environmental, geotechnical
Groundwater, mining, infrastructure, advanced environmental monitoring
pricing
Res2DInv and Res3DInv pricing plan
Res2DInv
USD $1,448.00  (excl. tax)
12 months named license
Features
  • checked 2D inversion for ERT and IP data
  • checked Export to Workbench and Oasis montaj
  • checked Live pseudosection updates
  • checked Model comparison tools
  • checked Time-lapse inversion for 2D surveys
license
Only 12 month named licences are available to purchase online. For shared and enterprise licences, please contact us.
Named license - allows unlimited use of the software for a single dedicated user during the subscription period.
Shared license - allows any number of users to access the software over the subscription period, limited to one user per seat at any given time.
shop
Go to Bentley's eStore
Seequent products can be purchased securely through Bentley's eStore. Seequent is the Bentley subsurface company.
Prices shown on Bentley's eStore will be displayed in your local currency excluding tax.
USD $2,800.00  (excl. tax)
Features
  • checked 3D model visualisation and export
  • checked Full 2D and 3D inversion
  • checked Support for large meshes and up to 256 GB RAM
  • checked Time-lapse inversion for 2D and 3D datasets
  • checked Vector array datasets (e.g. IRIS Full Waver)
license
shop
“We’ll spend a couple of days in the field running surveys, gathering the information, and putting the data into Res2DInv. This means that most of the time, we already know there is a water-bearing formation before we even start to drill. Or we know not to waste money drilling because there’s saltwater intrusion and it’s obvious in the results. It just works.”
Chris Hough, Global Fleet Manager - Living Water International
insights & impact
Res2DInv and Res3DInv live in action
Explore case studies and articles showcasing Res2DInv and Res3DInv's diverse real-world applications
Get more from your resistivity and IP data with fast, field-ready inversion tools for 2D and 3D subsurface modelling.
Resources
Free, on-demand training and support resources
Accelerate your Res2DInv and Res3DInv usage with support from our team of geophysics experts
Seequent Learning Centre
Onboard quickly and enhance your skills with our free, comprehensive online learning courses.
User Community
Grow your geoscience knowledge, connect with peers, and share insights from using Res2DInv and Res3DInv with others in your field.
Res2DInv & Res3DInv Help & support
Available on demand, anytime, anywhere. Find answers to your technical questions or speak with an expert.
