PLAXIS 3D
Reliable and powerful 3D finite element analysis
Solve your most complex geotechnical challenges dots
PLAXIS 3D enables geotechnical engineers to perform advanced three-dimensional finite element analysis for high-profile projects, including excavations, embankments, foundations, tunnelling, mining, and geomechanics.
KEY BENEFITS
Complex analysis made easy
Work quickly and seamlessly
Intuitive geotechnical workflows with several input modes to easily create a subsurface model with structures, loads, or flow boundary conditions.  
Simulate construction processes 
Realistically assess stress, displacements and safety using constitutive models, a staged construction mode, and various calculation types.
Maximise safety
Accurately model ground-structure interaction and dewatering through advanced soil and rock material models, structural elements, and flow analysis.
Analyse fractured rock masses 
Use discontinuity and reinforcement elements to assess surface settlements or rock mass responses to tunnelling, mining or reservoir depletion.
Automate workflows 
Automate model build up and design process or build custom applications with Python scripting to run in PLAXIS 3D.
Integrated workflows
Avoid redundant data entry by leveraging integrations between PLAXIS and other Seequent products or easily import industry-standard CAD data formats. 
topographic vector
PRODUCT PLANS
Explore PLAXIS 3D plans
PLAXIS 3D
PLAXIS 3D offers comprehensive functionality to perform advanced three-dimensional finite element analysis for high-profile projects. With three product plans to choose from, you can address creep, steady-state groundwater, consolidation analysis, dynamics and other time-dependent effects.
Buy now
shop
Proceed to cart
Seequent products can be purchased securely through Bentley's eStore. Seequent is the Bentley subsurface company.
Prices shown on Bentley's eStore will be displayed in your local currency excluding tax.
PLAXIS 3D Advanced
Enhance your geotechnical design capabilities with more advanced features and material models to consider creep or flow-deformation coupling through consolidation analysis. Also includes a multicore solver that adds powerful functionality so you can solve problems even faster.
Buy now
shop
Proceed to cart
PLAXIS 3D Ultimate
Get the functionality you need to deal with the most challenging geotechnical projects. With PLAXIS 3D Ultimate, you can analyse the effects of vibration from earthquakes or moving traffic loads in soil and rock or simulate complex hydrological conditions with time-dependent water level and flow variations.
Buy now
shop
Proceed to cart
Geotechnical Analysis 3D WorkSuite
The Geotechnical Analysis 3D WorkSuite includes PLAXIS 3D Ultimate and GeoStudio 3D Advanced, making it the most comprehensive 3D option.
Buy now
shop
Proceed to cart
Geotechnical Analysis 3D WorkSuite includes the following:
PLAXIS 3D Ultimate
Feature comparison
Compare PLAXIS 3D features
PLAXIS 3D
PLAXIS 3D Advanced
PLAXIS 3D Ultimate
Calculation types
Consolidation deformation calculation type
null
checked
checked
Dynamic deformation calculation type
null
null
checked
Dynamic with consolidation deformation calculation type
null
null
checked
Field Stress initial calculation type
checked
checked
checked
Flow Only initial calculation type
null
null
checked
Fully coupled flow-deformation calculation type
null
null
checked
Gravity Loading initial calculation type
checked
checked
checked
K0 Procedure initial calculation type
checked
checked
checked
Phreatic Level pore pressure calculation type
checked
checked
checked
Plastic deformation calculation type
checked
checked
checked
Safety deformation calculation type
checked
checked
checked
Steady-State Groundwater Flow pore pressure calculation type
null
checked
checked
Transient Groundwater Flow pore pressure calculation type
null
null
checked
Use Pore Pressures from Previous Phase pore pressure calculation type
checked
checked
checked
Interoperability
Automatic geotechnical model generation from/by OpenTunnel Designer
checked
checked
checked
CAD import and export
checked
checked
checked
Generate stratigraphy from imported CPT logs
checked
checked
checked
Import Leapfrog surfaces from Seequent Central
checked
checked
checked
ProjectWise integration, loading from and saving to ProjectWise server
checked
checked
checked
Remote scripting for input, output, and SoilTest
checked
checked
checked
Soil and rock material models
Concrete
null
checked
checked
Hardening soil
checked
checked
checked
Hardening soil small strain stiffness
checked
checked
checked
Hoek-Brown, with parameter guide
checked
checked
checked
Jointed Rock Model
checked
checked
checked
Linear Elastic
checked
checked
checked
Modified Cam-Clay
checked
checked
checked
Mohr-Coulomb
checked
checked
checked
NGI-ADP
checked
checked
checked
Sekiguchi-Ohta (inviscid)
null
checked
checked
Sekiguchi-Ohta (viscid)
null
checked
checked
Soft soil
null
checked
checked
Soft soil creep
null
checked
checked
UBC3D-PLM (liquefaction)
null
null
checked
UDCAM-S and cyclic accumulation tool
null
checked
checked
User-Defined soil and rock models
Barcelona Basic Model
null
checked
checked
Clay and Sand model (CASM)
null
checked
checked
Creep-SCLAY1S
null
checked
checked
Fluid
null
checked
checked
Generalised Hardening Soil
null
checked
checked
Hoek-Brown with Softening (strength softening and GSI softening models)
null
checked
checked
Hypoplastic Model with Inter-Granular Strain
null
checked
checked
Isotropic Jointed Rock with Mohr-Coulomb Failure Criterion
null
checked
checked
Masonry
null
checked
checked
N2PC-MCT Rock Creep (Norton-based double power creep with Mohr-Coulomb and tension cut-off failure surface)
null
checked
checked
NorSand
null
checked
checked
Overconsolidated Clay
null
checked
checked
SANISAND-MS
null
checked
checked
SHANSEP Mohr-Coulomb
null
checked
checked
SHANSEP NGI-ADP
null
checked
checked
Swelling rock
null
checked
checked
Visco-Elastic Perfectly Plastic
null
checked
checked
PRICING
A plan for every need
PLAXIS 3D
USD $11,083.00 (excl. tax)
Includes
license
Only 12 month named licences are available to purchase online. For shared and enterprise licences, please contact us.
Named license - allows unlimited use of the software for a single dedicated user during the subscription period.
Shared license - allows any number of users to access the software over the subscription period, limited to one user per seat at any given time.
shop
Proceed to cart
PLAXIS 3D Advanced
USD $14,831.00 (excl. tax)
Includes
license
shop
Proceed to cart
PLAXIS 3D Ultimate
USD $18,182.00 (excl. tax)
Includes
license
shop
Proceed to cart
USD $20,885.00 (excl. tax)
Includes
  • checked GeoStudio 3D Advanced
  • checked PLAXIS 3D Ultimate
license
shop
Proceed to cart
For enterprise, shared, and other PLAXIS 3D ​licences​, talk to us 
Contact us
shop
Proceed to cart
CUSTOMER​ STORIES
PLAXIS ​at work​
​See the impact of​ PLAXIS in research and industry 
We have 30 years' experience enabling expert geotechnical analysis in research and industry.
RESOURCES
Training and support
PLAXIS Training
Redeem tokens you get with your PLAXIS purchase for expert services and training that meet your onboarding and project needs.
PLAXIS Webinars
Explore our on-demand webinars with general tips and tricks or specialised guides to take your workflows to the next level.
PLAXIS Support
Get expert support from our global team of geo-engineering professionals when you submit a ticket on the customer portal.
