GeoStudio 2D
2D geotechnical analysis software for soil and rock
A comprehensive solution for geotechnical analysis dots
GeoStudio 2D offers a range of numerical analysis tools for simulating conditions at and below the ground surface. From natural soil and rock slopes, to dewatering systems or tailings storage facilities, you can use GeoStudio 2D to model the conditions you need for better insights into your geotechnical projects.
Key Benefits
Confidently simulate surface and subsurface conditions
Collaborate seamlessly
Leverage the power of the Seequent portfolio, including Leapfrog and PLAXIS, to share geometry and materials via a seamless cloud-based workflow.
Integrated stability analyses
Easily incorporate finite element results into a limit equilibrium analysis for a comprehensive view of slope stability.
Analyse complex ground behaviour
Use the comprehensive constitutive model library for soil and rock, in all your stability, groundwater flow, and stress-strain analyses.
One model, multiple analyses
Explore complex geotechnical processes using a number of analyses, geometries, and dimensions in a single project file.
Insights through visualisation
Graphing and visualisation tools to help you interpret results, compare them to the physical system, and gain deep insights into the problem at hand.
Start simple, add complexity
Explore geotechnical systems with multi-analysis and multi-geometry capabilities, and a simple-to-complex iterative workflow to unlock knowledge.
topographic vector
Product Plans
Explore GeoStudio 2D product plans
GeoStudio 2D
GeoStudio 2D offers the foundational capability to perform limit equilibrium slope stability analysis in soil and rock in two dimensions. With three product plans to choose from, you can address problems that require the consideration of groundwater flow, finite element stresses or pore water pressures, or dynamic stresses.
Buy now
shop
Proceed to cart
Seequent products can be purchased securely through Virtuosity, Bentley's e-store. Seequent is the Bentley subsurface company.
Prices shown on Virtuosity will be displayed in your local currency excluding tax.
GeoStudio 2D includes the following:
SLOPE/W
SLOPE/W is the leading limit equilibrium slope stability software for soil and rock slopes, analysing both simple and complex problems for a variety of slip surface shapes, pore water pressure conditions, soil properties, and loading conditions.
GeoStudio 2D Advanced
GeoStudio 2D Advanced has the capabilities of the GeoStudio 2D, as well as the ability simulate steady-state and transient groundwater flow in both saturated and unsaturated soil and rock. GeoStudio 2D Advanced can be used to analyse geotechnical engineering challenges such as rapid drawdown analysis, complex seepage analyses and much more.
Buy now
shop
Proceed to cart
GeoStudio 2D Advanced includes the following:
SEEP/W
SEEP/W is a powerful finite element software product for modelling groundwater flow in porous media. SEEP/W can model simple saturated steady-state problems or sophisticated saturated/unsaturated transient analyses with atmospheric coupling at the ground surface.
SLOPE/W
GeoStudio 2D Ultimate
GeoStudio 2D Ultimate expands the capability of GeoStudio 2D Advanced with functionality to analyse static and dynamic stress and deformation within soil or rock including coupled consolidation, finite element stress stability, and the ability to use finite element results in the limit equilibrium analysis.
Buy now
shop
Proceed to cart
GeoStudio 2D Ultimate includes the following:
QUAKE/W
QUAKE/W is a powerful finite element software product for modelling earthquake liquefaction and dynamic loading. QUAKE/W determines the motion and excess pore water pressures that arise due to earthquake shaking, blasts, or sudden impact loads.
SEEP/W
SIGMA/W
SIGMA/W is a powerful finite element software product for modelling stress and deformation in soil, rock, and structures. SIGMA/W analyses may range from simple linear elastic simulations to soil-structure interaction problems with nonlinear material models.
SLOPE/W
Geotechnical Analysis 2D WorkSuite
The Geotechnical Analysis 2D WorkSuite includes PLAXIS 2D Ultimate and GeoStudio 2D Ultimate, making it the most comprehensive 2D option.
Buy now
shop
Proceed to cart
Geotechnical Analysis 2D WorkSuite includes the following:
PLAXIS 2D Ultimate
Feature comparison
Compare GeoStudio 2D features
GeoStudio 2D
Groundwater seepage
2D cross-section, 2D axisymmetric, and 1D geometry options
null
checked
checked
Convenient initial pore water pressure condition definition
null
checked
checked
Estimation routines for defining hydraulic functions
null
checked
checked
Hydraulic boundary conditions, including specialised boundary conditions for soil-atmosphere coupling
null
checked
checked
Optional isothermal vapor transfer
null
checked
checked
Results graphing and visualisation options, including isosurfaces and contouring
null
checked
checked
Saturated/unsaturated formulation
null
checked
checked
Steady-state or transient groundwater flow
null
checked
checked
Under-relaxation and convergence strategies for pore water pressure computation
null
checked
checked
Slope stability
Automated strength reduction stability analysis
null
null
checked
Comprehensive material model library for soil and rock
checked
checked
checked
Finite element stress-based stability analysis
null
null
checked
Full range of slip surface search techniques
checked
checked
checked
Newmark deformation stability analysis
null
null
checked
Partial factor analysis capabilities including limit state design support
checked
checked
checked
Pore water pressure definition with finite element seepage analysis
null
checked
checked
Probabilistic and sensitivity analysis capabilities
checked
checked
checked
Reinforcement definition options including vendor reinforcement library
checked
checked
checked
Rigorous limit equilibrium slope stability formulation
checked
checked
checked
Staged pseudo static formulation
checked
checked
checked
Staged rapid drawdown functionality
checked
checked
checked
Surcharge and seismic load functionality
checked
checked
checked
Thirteen limit equilibrium methods including Morgenstern-Price and Spencer
checked
checked
checked
Static and dynamic stresses
Complete range of stress and deformation boundary conditions
null
null
checked
Comprehensive stress-strain constitutive model list, including non-linear soil and rock material models
null
null
checked
Coupled stress and pore water pressure formulation for consolidation analysis
null
null
checked
Dynamic and static stress analyses to model post-earthquake deformation and excess pore water pressures dissipation
null
null
checked
Incremental stress-strain formulation
null
null
checked
Multiple options for In situ stress definition, including gravity activation, K0 procedure, and field stresses
null
null
checked
Stress redistribution analysis
null
null
checked
Stress-update algorithm for handling non-linear material models
null
null
checked
Structural element library for modelling reinforcement, retaining walls and more
null
null
checked
Unloading/loading stress analysis with straightforward construction sequence simulation
null
null
checked
Pricing
GeoStudio 2D pricing plans
GeoStudio 2D
USD $2,840.00 (excl. tax)
Includes
  • checked SLOPE/W
license
Only 12 month named licences are available to purchase online. For shared and enterprise licences, please contact us.
Named license - allows unlimited use of the software for a single dedicated user during the subscription period.
Shared license - allows any number of users to access the software over the subscription period, limited to one user per seat at any given time.
shop
Proceed to cart
USD $4,260.00 (excl. tax)
Includes
  • checked SEEP/W
  • checked SLOPE/W
license
shop
Proceed to cart
USD $5,680.00 (excl. tax)
Includes
  • checked QUAKE/W
  • checked SEEP/W
  • checked SIGMA/W
  • checked SLOPE/W
license
shop
Proceed to cart
USD $9,520.00 (excl. tax)
Includes
  • checked GeoStudio 2D Ultimate
  • checked PLAXIS 2D Ultimate
license
shop
Proceed to cart
For enterprise, shared subscriptions and other GeoStudio 2D licenses, talk to us
Contact us
shop
Proceed to cart
Resources
Accelerate your GeoStudio 2D usage with a fundamentals course, knowledge base articles, or support from our team of geotechnical experts.
Seequent Learning Centre
Get started fast or upskill whilst working with our onboarding and advanced free eLearning courses available for GeoStudio.
Seequent Knowledge Base
Search our knowledge base for quick reference articles when needing to troubleshoot or resolve any errors you encounter.
Seequent Support
Expert support from our global team of geoscience professionals when you submit a ticket on the MySeequent customer portal.
Customer stories
GeoStudio live in action
Explore webinars, case studies and articles showcasing GeoStudio's diverse real-world applications
We have over 40 years’ experience in enabling geotechnical analysis in research and industry.
