Photo of a open pit mine
Oasis montaj
Geophysical software for processing, filtering, and interpreting survey data.
Transform geophysical data into decisions  dots
Oasis montaj is industry-standard software for geophysicists to process, filter, and model geophysical survey data. It enables users to create reliable subsurface interpretations by integrating large geophysical datasets with other geoscience data in a user-friendly application. This software is ideal for geophysicists and geological survey bodies in the mineral resources, energy, environmental, or on/offshore infrastructure industries who require accuracy, power, and versatility.
Get more from your data
Key Benefits
Large-scale data handling
Import, process, and manage large volumes of varied geoscientific data types and formats without database size constraints.
Industry-trusted solutions
Widely recognised and accepted for tenders by governmental and private companies, with industry-standard database and grid formats available for download from governmental data services.
Unified workflows
Streamline geophysical workflows with tools for acquiring, processing, and interpreting survey data. Create detailed models that integrate seamlessly with Leapfrog and share results via Central for efficient collaboration and data management.
Coordinate transformations
On-the-fly reprojection allows you to effortlessly combine geospatial datasets that use different coordinate reference systems.
Gridding and visualisation
Create and visualise 2D and 3D geophysical data grids, interpolate data with advanced gridding methods, and merge geophysical grids quickly and accurately.
Advanced filtering
Apply a wide range of filters or use the math expression builder to process and analyse data to improve the precision of your interpretations.
topographic vector
Product Options
Explore Oasis montaj
Oasis montaj
Use Oasis montaj to filter and process gravity, magnetic, and electromagnetic survey data. Supporting a broad range of geophysical workflows and data formats, Oasis montaj makes it easy to import and georeference data with user-friendly tools for coordinate system transformations, filtering, and visualising (gridding) the data.
Contact us
Oasis montaj for energy applications
Oasis montaj Basin Modelling includes all the processing functionality of Oasis montaj plus additional tools for energy exploration. Create robust basin models by integrating geophysical data with seismic, well, and geological constraints to refine and validate your 2D geophysical models. Apply data corrections and 2D Fourier filters to clean, transform, and enhance your data and interpretation.
Contact us
A comprehensive bundle
Oasis montaj Ultimate provides full access to all Oasis montaj tools and extensions, including the Resistivity and Induced Polarisation (DC-IP) Extension and radiometric processing tools. It features advanced gravity and magnetic capabilities, such as 3D layered-earth modelling and depth-to-source estimation, ensuring thorough and precise geophysical analysis.
Contact us
Product Options
Oasis montaj
12-month named or shared license
Features:
  • checkedLarge-scale data handling
  • checkedFormat compatability
  • checkedData processing
  • checkedCoordinate transformations
  • checkedAdvanced gridding
  • checkedIndustry-trusted solutions
Features:
  • checkedAll oasis montaj features
  • checkedEnergy sector workflows
  • checkedSeismic integration
  • checked2D Layered Earth Modelling
  • checked2D Fourier filtering and modelling
Features:
  • checkedAll oasis montaj basin modelling features
  • checkedAll extensions (Excluding UXO and VOXI)
  • checked3D Layered earth modelling
  • checkedDepth to source estimation
  • checkedSubscription flexibility
For more information about Oasis montaj products and pricing, talk to us
Contact us
Oasis montaj extensions and add-ons
All extensions and add-ons require an Oasis montaj subscription to purchase and run
Acquisition
  • Plan and conduct magnetic, gravity, and electromagnetic surveys
  • Quality control (QC) data in the field
Processing
  • Import and correct gravimeter data
  • Apply type-specific corrections
  • Perform gravity reduction and terrain correction
  • Apply 1D and 2D Fourier domain filters
Interpretation
  • Transform your data to locate geologic contacts
  • Estimate source depth with 3D Euler deconvolution
  • Analyse magnetic data to identify kimberlite-type sources
  • Import, process, and visualise resistivity and IP data
  • Perform quality control checks Georeference electrode positions
Geology
  • Integrate geological and geochemical data into geophysical models
  • Generate drill hole sections
  • Create plan and level maps
Radiometric Processing
  • Import, process, and visualise gamma-ray spectrometry data
  • Apply corrections for altitude, background radiation, and spectral overlap
Offshore hazard detection
  • Locate and analyse UXO, cables, and pipes from offshore magnetic (total field and gradiometer) survey data
  • Perform inverse modelling to estimate anomaly characteristics
  • Tailor seabed survey planning and reporting to sensors and arrays
  • Assess infrastructure project risk
Onshore hazard detection
  • Locate and analyse UXO targets, pipelines, and cables using magnetic and electromagnetic survey data
  • Optimize survey planning and reporting for accurate hazard assessment
Onshore hazard classification
  • Import and process advanced electromagnetic sensor data for UXO classification
  • Perform advanced target analysis and classification
  • Adhere to the US Department of Defence’s (DAGCAP) standards with HDF v1 format support and quality control tests.
VOXI Essentials
  • Combine geological, geochemical, structural, and geophysical data
  • Leverage cloud-powered speed and efficiency
  • Generate 3D voxel distributions using geophysical forward and inverse modelling
VOXI Gravity Gradient
  • Create 3D rock density models using forward and inverse modelling of gravity gradiometry data
  • Model density using the entire multi-channel gravity gradiometer dataset
VOXI IP and Resistivity
  • Create 3D models of conductivity and chargeability using forward and inverse modelling of IP and resistivity data
  • Handle arbitrary electrode layouts accurately for diverse survey configurations
VOXI Frequency Domain EM
  • Generate layered earth voxel conductivity models from frequency-domain electromagnetic data
  • Ideal for airborne frequency domain systems like Dighem or Resolve
VOXI Time Domain EM
  • Generate detailed subsurface conductivity models from time-domain electromagnetic data.
  • Supports various transmitter configurations, including SkyTEM, Geotech VTEM, and NRG Xcite
VOXI Modelling Services
  • Custom modelling solutions
  • Support for complex geological investigations
  • Expert guidance and tailored approaches for interpretation
Contact us
Insights & impact
Oasis montaj at work
Explore case studies and articles showcasing how Oasis montaj is used in research and industry.
Over 30 years of industry-leading geophysical processing, filtering, and interpretation
Resources
Resources
Improve your Oasis montaj skills with training, articles, or support from our team of geophysical experts.
Oasis montaj training
Get started fast or upskill with our onboarding and advanced free eLearning courses available for Oasis montaj.
Oasis montaj webinars
Explore our on-demand webinar library for the latest release updates, in-depth tutorials, and comprehensive guides to enhance your workflows.
Seequent Support
Get expert support from our global team of geoscience professionals when you submit a ticket on the MySeequent customer portal.
