PLAXIS 2D
2D geotechnical finite element analysis
Streamline your 2D finite element analysis dots
Reliably analyse soil and rock to assess deformation and stability under the effects of ground-structure interaction, groundwater flow, heat flow or earthquakes. PLAXIS 2D is trusted by geotechnical engineers worldwide for analysing excavations, embankments, foundations, tunnels, and more.
KEY BENEFITS
Perform geotechnical analysis faster
Work quickly and seamlessly
Intuitive geotechnical workflows with several input modes to easily create a subsurface model with structures, loads, or flow boundary conditions.
Simulate construction processes
Realistically assess stress, displacements and safety using constitutive models, a staged construction mode, and various calculation types.
Maximise safety
Accurately model ground-structure interaction and dewatering through advanced soil and rock material models, structural elements, and flow analysis.
Analyse fractured rock masses
Use discontinuity and reinforcement elements to assess surface settlements or rock mass responses to tunnelling, mining or reservoir depletion.
Automate workflows
Automate model build up and design process or build custom applications with Python scripting to run in PLAXIS 2D.
Integrated workflows
Avoid redundant data entry by leveraging integrations between PLAXIS and other Seequent products or easily import industry-standard CAD data formats.
topographic vector
PRODUCT PLANS
Explore PLAXIS 2D plans
PLAXIS 2D
PLAXIS 2D offers comprehensive functionality for both everyday deformation and safety analysis of soil and rock, as well as the most challenging geotechnical projects. With three product plans to choose from, you can address creep, steady-state groundwater or thermal flow, consolidation analysis, dynamics and other time-dependent effects.
Buy now
shop
Proceed to cart
Seequent products can be purchased securely through Virtuosity, Bentley's e-store. Seequent is the Bentley subsurface company.
Prices shown on Virtuosity will be displayed in your local currency excluding tax.
PLX2D_ Embankment settlements-consolidation
PLAXIS 2D Advanced
PLAXIS 2D Advanced enhances your geotechnical design capabilities with more advanced features and material models, so you can include creep, flow-deformation coupling through consolidation analysis, and steady-state groundwater or heat flow. All powered by a multicore solver for faster problem solving.
Buy now
shop
Proceed to cart
PLAXIS 2D Ultimate
PLAXIS 2D Ultimate adds functionality built for the most challenging geotechnical projects. In one comprehensive package, you can analyse the effects of vibrations from earthquakes or traffic, simulate hydrological, time-dependent water level variations, assess transient heat flow, and more.
Buy now
shop
Proceed to cart
Geotechnical Analysis 2D WorkSuite
The Geotechnical Analysis 2D WorkSuite includes PLAXIS 2D Ultimate and GeoStudio 2D Ultimate, making it the most comprehensive 2D option.
Buy now
shop
Proceed to cart
Geotechnical Analysis 2D WorkSuite includes the following:
PLAXIS 2D Ultimate
Feature comparison
PLAXIS 2D
PLAXIS 2D Advanced
PLAXIS 2D Ultimate
Calculation types
Consolidation deformation calculation type
null
checked
checked
Dynamic deformation calculation type
null
null
checked
Dynamic with consolidation deformation calculation type
null
null
checked
Earth Gradient thermal pressure calculation type
null
checked
checked
Field Stress initial calculation type
checked
checked
checked
Flow Only initial calculation type
null
null
checked
Fully coupled flow-deformation calculation type
null
null
checked
Gravity Loading initial calculation type
checked
checked
checked
Ignore Temperature thermal pressure calculation type
null
checked
checked
K0 Procedure initial calculation type
checked
checked
checked
Phreatic Level pore pressure calculation type
checked
checked
checked
Plastic deformation calculation type
checked
checked
checked
Safety deformation calculation type
checked
checked
checked
Steady-State Groundwater Flow pore pressure calculation type
null
checked
checked
Steady-State Thermal Flow thermal pressure calculation type
null
checked
checked
Transient Groundwater Flow pore pressure calculation type
null
null
checked
Transient Thermal Flow thermal pressure calculation type
null
null
checked
Use Pore Pressures from Previous Phase pore pressure calculation type
checked
checked
checked
Use temperatures from Previous Phase thermal pressure calculation type
null
checked
checked
Interoperability
Automatic geotechnical model generation from/by OpenTunnel Designer
checked
null
null
CAD import and export
checked
checked
checked
Generate stratigraphy from imported CPT logs
checked
checked
checked
Import Leapfrog cross sections from Seequent Central
checked
checked
checked
PLAXIS 2D to 3D converter
checked
checked
checked
ProjectWise integration, loading from and saving to ProjectWise server
checked
checked
checked
Remote scripting for input, output, and SoilTest
checked
checked
checked
Soil and rock material models
Concrete
null
checked
checked
Hardening soil
checked
checked
checked
Hardening soil small strain stiffness
checked
checked
checked
Hoek-Brown, with parameter guide
checked
checked
checked
Jointed Rock Model
checked
checked
checked
Linear Elastic
checked
checked
checked
Modified Cam-Clay
checked
checked
checked
Mohr-Coulomb
checked
checked
checked
NGI-ADP
checked
checked
checked
Sekiguchi-Ohta (inviscid)
null
checked
checked
Sekiguchi-Ohta (viscid)
null
checked
checked
Soft soil
null
checked
checked
Soft soil creep
null
checked
checked
UBC3D-PLM (liquefaction)
null
null
checked
UDCAM-S and cyclic accumulation tool
null
checked
checked
User-Defined soil and rock models
Barcelona Basic Model
null
null
checked
Clay and Sand model (CASM)
null
checked
checked
Creep-SCLAY1S
checked
checked
checked
Fluid
null
checked
checked
Frozen and Unfrozen Soil
null
null
checked
Generalised Hardening Soil
checked
checked
checked
Hoek-Brown with Softening (strength softening and GSI softening models)
null
checked
checked
Hypoplastic Model with Inter-Granular Strain
null
checked
checked
Isotropic Jointed Rock with Mohr-Coulomb Failure Criterion
null
checked
checked
Masonry
checked
checked
checked
N2PC-MCT Rock Creep (Norton-based double power creep with Mohr-Coulomb and tension cut-off failure surface)
null
checked
checked
NorSand
null
checked
checked
Overconsolidated Clay
checked
checked
checked
PM4SAND
null
null
checked
PM4SILT
null
null
checked
SHANSEP Mohr-Coulomb
checked
checked
checked
SHANSEP NGI-ADP
checked
checked
checked
Swelling rock
null
checked
checked
Visco-Elastic Perfectly Plastic
checked
checked
checked
PRICING
PLAXIS 2D pricing plans
PLAXIS 2D
USD $3,939.00 (excl. tax)
12 months named license Includes
license
Only 12 month named licences are available to purchase online. For shared and enterprise licences, please contact us.
Named license - allows unlimited use of the software for a single dedicated user during the subscription period.
Shared license - allows any number of users to access the software over the subscription period, limited to one user per seat at any given time.
shop
Proceed to cart
PLAXIS 2D Advanced
USD $4,924.00 (excl. tax)
license
shop
Proceed to cart
PLAXIS 2D Ultimate
USD $7,016.00 (excl. tax)
license
shop
Proceed to cart
USD $8,880.00 (excl. tax)
  • checked GeoStudio 2D Ultimate
  • checked PLAXIS 2D Ultimate
license
shop
Proceed to cart
For enterprise, shared, and other PLAXIS 2D licences, talk to us
Contact us
shop
Proceed to cart
RESOURCES
Accelerate your PLAXIS 2D usage with training courses, on-demand webinars, or support from our team of geotechnical experts.
PLAXIS Training
Redeem tokens you get with your PLAXIS purchase for expert services and training that meets your onboarding and project needs.
PLAXIS Webinars
Explore our on-demand webinars with general tips and tricks or specialised guides to take your workflows to the next level.
PLAXIS Support
Get expert support from our global team of geo-engineering professionals when you submit a ticket on the customer portal.
Customer stories
PLAXIS at work
Read about the use and impact of PLAXIS in research and industry
We have 30 years' experience enabling expert geotechnical analysis in research and industry.
