This is a technical review of the RBF Interpolant tool aimed toward achieving robust and dynamic workflows in your numerical modelling.
We will take a deeper look at how Leapfrog Geo constructs a numerical model in order to build upon and provide a better understanding of the tools available at your disposal.
49 min
Video Transcript
1
00:00:11,105 –> 00:00:14,420
<v Suzzana>All right, hello and welcome everyone.</v>
2
00:00:14,420 –> 00:00:16,324
I make that 10 o’clock here in the UK.
3
00:00:16,324 –> 00:00:19,231
And so, let’s get started.
4
00:00:19,231 –> 00:00:23,050
Thank you for joining us today for this tech talk
5
00:00:23,050 –> 00:00:26,373
on Numeric Modelling in Leapfrog Geo.
6
00:00:26,373 –> 00:00:29,290
By way of introduction, my name is Suzanna.
7
00:00:29,290 –> 00:00:33,624
I’m a Geologist by background, based out of our UK office.
8
00:00:33,624 –> 00:00:36,510
With me today are my colleagues,
9
00:00:36,510 –> 00:00:39,930
James and Andre, both of whom will be on hand to help
10
00:00:39,930 –> 00:00:41,658
run this session.
11
00:00:41,658 –> 00:00:44,680
Now, our aim for this session is
12
00:00:44,680 –> 00:00:48,204
to really focus in on the interpolant settings
13
00:00:48,204 –> 00:00:52,240
that will most effectively improve your numeric models
14
00:00:52,240 –> 00:00:54,320
from the word go.
15
00:00:54,320 –> 00:00:56,820
Let me set the scene for my project today.
16
00:00:56,820 –> 00:00:59,817
This is a copper gold porphyry deposit.
17
00:00:59,817 –> 00:01:01,325
And from the stats,
18
00:01:01,325 –> 00:01:06,325
we know that it is our Early Diorite unit
19
00:01:06,920 –> 00:01:10,560
that is our highest grade domain.
20
00:01:10,560 –> 00:01:13,220
For the purpose of today’s session,
21
00:01:13,220 –> 00:01:17,081
I’m going to focus on modelling the gold assay information,
22
00:01:17,081 –> 00:01:20,650
so from these drillholes, but in reality,
23
00:01:20,650 –> 00:01:24,750
I could choose to model any type of numerical value here,
24
00:01:26,320 –> 00:01:29,010
for example, RQD data.
25
00:01:29,010 –> 00:01:31,160
If that is the workflow that you’re interested in,
26
00:01:31,160 –> 00:01:34,197
then I’d recommend you head over to the Seequent website,
27
00:01:34,197 –> 00:01:36,560
where there are a couple of videos
28
00:01:36,560 –> 00:01:38,713
on this topic already available.
29
00:01:40,000 –> 00:01:44,520
So coming down to my Numeric Models folder,
30
00:01:44,520 –> 00:01:48,730
I’m now going to select a new RBF interpolant.
31
00:01:51,500 –> 00:01:53,840
And in the first window,
32
00:01:53,840 –> 00:01:58,103
start to specify my initial inputs and outputs.
33
00:01:59,310 –> 00:02:02,130
First, I’m going to want to specify
34
00:02:02,130 –> 00:02:04,440
some suitable numeric values.
35
00:02:04,440 –> 00:02:05,720
So in this case,
36
00:02:05,720 –> 00:02:09,463
I’m going to use my composited gold assay table,
37
00:02:10,407 –> 00:02:15,407
but I can also choose to apply any applicable query filter.
38
00:02:15,800 –> 00:02:20,658
Now, in this case, as part of my initial validation steps,
39
00:02:20,658 –> 00:02:25,658
I actually created a new column in my collar table
40
00:02:25,847 –> 00:02:30,847
called ‘Valid’ simply to help me identify which drillholes
41
00:02:32,300 –> 00:02:35,017
I want to use in my modelling.
42
00:02:35,017 –> 00:02:37,380
I did this by first of all,
43
00:02:37,380 –> 00:02:40,640
creating a new category selection
44
00:02:40,640 –> 00:02:42,430
to make those initial selections
45
00:02:43,320 –> 00:02:46,776
then created a very simple query filter
46
00:02:46,776 –> 00:02:51,776
simply to exclude any of those that are invalid.
47
00:02:51,900 –> 00:02:53,830
And actually for the most part,
48
00:02:53,830 –> 00:02:57,290
it’s just this one hole at the bottom
49
00:02:57,290 –> 00:02:58,963
that I chose to exclude.
50
00:03:00,960 –> 00:03:04,416
As I work on my interpretation or indeed bring in more data,
51
00:03:04,416 –> 00:03:07,000
then it’s always useful to have flexibility
52
00:03:07,000 –> 00:03:10,310
like this built into your drillhole management workflow.
53
00:03:10,310 –> 00:03:13,580
So I would encourage you to set up something similar
54
00:03:13,580 –> 00:03:15,243
if not already done so.
55
00:03:16,189 –> 00:03:20,660
But for now though, let me just go back to my
56
00:03:20,660 –> 00:03:23,973
RBF interpolant definition again,
57
00:03:25,791 –> 00:03:30,791
and let’s start to talk about the interpolant boundary.
58
00:03:32,950 –> 00:03:37,950
Now, the default here is set to be our clipping boundary.
59
00:03:40,850 –> 00:03:42,660
If you don’t know what that is,
60
00:03:42,660 –> 00:03:43,700
or if you want to set that,
61
00:03:43,700 –> 00:03:46,130
then you can actually do that from either the Topography
62
00:03:46,130 –> 00:03:49,950
or indeed the GIS data folder.
63
00:03:49,950 –> 00:03:54,360
So I could choose to manually change this boundary
64
00:03:54,360 –> 00:03:58,360
or to enclose it around any object
65
00:03:58,360 –> 00:03:59,920
that already exists in my project,
66
00:03:59,920 –> 00:04:04,663
or indeed an existing model boundary or volume.
67
00:04:05,960 –> 00:04:09,950
Whatever I set here in my interpolant boundary
68
00:04:09,950 –> 00:04:13,788
is going to be linked to the surface filter,
69
00:04:13,788 –> 00:04:17,350
or by default, is linked to the surface filter
70
00:04:17,350 –> 00:04:22,023
which in itself controls which values can go into the model.
71
00:04:22,920 –> 00:04:27,220
I’m just going to bring a quick slice view into my scene,
72
00:04:27,220 –> 00:04:28,955
just to sort of help us visualise
73
00:04:28,955 –> 00:04:31,183
what I’m about to talk about.
74
00:04:32,020 –> 00:04:33,180
But I will explain this, as this is
75
00:04:33,180 –> 00:04:36,531
basically just a slice of my geological model
76
00:04:36,531 –> 00:04:41,423
just with those sort of gold values seen in the scene here.
77
00:04:43,120 –> 00:04:45,960
Typically your interpolant boundary
78
00:04:45,960 –> 00:04:50,170
would be set to enclose the entire data set.
79
00:04:51,490 –> 00:04:56,150
In which case, all of your specified input values
80
00:04:56,150 –> 00:04:57,570
will become interpolated.
81
00:04:57,570 –> 00:05:00,150
So that’s kind of what we’re seeing in the scene at the moment.
82
00:05:00,150 –> 00:05:02,975
It’s just a simple view of everything
83
00:05:02,975 –> 00:05:06,833
that’s in my data and in my project.
84
00:05:08,380 –> 00:05:09,746
I could choose however,
85
00:05:09,746 –> 00:05:14,380
to set a boundary around an existing volume.
86
00:05:14,380 –> 00:05:15,320
So for example,
87
00:05:15,320 –> 00:05:18,320
if I want to just specifically look at my Early Diorite
88
00:05:18,320 –> 00:05:19,963
which is anything here in green,
89
00:05:20,830 –> 00:05:23,550
then I can choose to do that.
90
00:05:23,550 –> 00:05:28,550
And if I just turn that on now, then you can see,
91
00:05:28,950 –> 00:05:32,090
we’re just seeing that limited subset
92
00:05:32,090 –> 00:05:34,303
of input values in that case.
93
00:05:35,187 –> 00:05:39,230
Now, interestingly, if I wanted to at this point
94
00:05:39,230 –> 00:05:42,900
mimic a soft boundary around the Early Diorite,
95
00:05:42,900 –> 00:05:47,180
So for example, some sort of value buffer
96
00:05:47,180 –> 00:05:49,853
say it’s about 50 meters away,
97
00:05:50,800 –> 00:05:52,723
which is this orange line here.
98
00:05:53,700 –> 00:05:58,683
Then I could incorporate this also into my Surface Filter.
99
00:06:00,300 –> 00:06:02,240
And again, by doing, say,
100
00:06:02,240 –> 00:06:07,240
so if I now select this distance function here,
101
00:06:08,260 –> 00:06:12,270
then again, we’re going to see this update
102
00:06:12,270 –> 00:06:16,393
on which input values can be used into the model.
103
00:06:17,610 –> 00:06:20,610
But now though let’s not complicate things too much.
104
00:06:20,610 –> 00:06:24,480
I’m just simply going to use the same boundary
105
00:06:25,330 –> 00:06:27,803
as my geological model.
106
00:06:28,870 –> 00:06:33,196
And I’m also going to bring down my surface resolution
107
00:06:33,196 –> 00:06:35,630
to something a bit more reasonable.
108
00:06:35,630 –> 00:06:39,580
Now, a rule of thumb with drillhole data would be
109
00:06:39,580 –> 00:06:42,690
to set this to your composite length.
110
00:06:42,690 –> 00:06:45,752
So as to equal the triangulation
111
00:06:45,752 –> 00:06:48,980
or indeed some multiple of this,
112
00:06:48,980 –> 00:06:52,752
if you find the processing time takes too much of a hit.
113
00:06:52,752 –> 00:06:55,360
For this particular data set,
114
00:06:55,360 –> 00:06:59,169
I have six metre length composites already defined.
115
00:06:59,169 –> 00:07:02,800
So I’m going to bring surface resolution down
116
00:07:02,800 –> 00:07:04,913
to multiple of that, 12 in this case.
117
00:07:06,490 –> 00:07:08,660
And of course those composites are there
118
00:07:08,660 –> 00:07:10,400
in order to help normalise
119
00:07:10,400 –> 00:07:12,913
and reduce the variance of my data.
120
00:07:13,870 –> 00:07:18,770
If I didn’t already have numeric composites set up
121
00:07:18,770 –> 00:07:21,186
in my Drillhole Data folder,
122
00:07:21,186 –> 00:07:25,770
then I could actually go into find these here
123
00:07:25,770 –> 00:07:27,193
as well directly.
124
00:07:28,608 –> 00:07:31,840
But now though, let me just go back and use those,
125
00:07:31,840 –> 00:07:33,483
those composites that I have,
126
00:07:35,180 –> 00:07:39,133
and for now, let’s just say OK to this and let it run.
127
00:07:44,920 –> 00:07:47,884
All right, now, there will be some times here
128
00:07:47,884 –> 00:07:51,179
that it’s going to be easier just to jump into models
129
00:07:51,179 –> 00:07:52,817
that have already been set up
130
00:07:52,817 –> 00:07:54,940
and I think this is one of those cases.
131
00:07:54,940 –> 00:07:59,723
So let me just bring in what that is going to generate,
132
00:08:02,120 –> 00:08:07,120
which is essentially our first pass gold numeric model.
133
00:08:09,980 –> 00:08:12,330
If I stick the legend on,
134
00:08:12,330 –> 00:08:14,030
then you’ll start to get idea
135
00:08:14,030 –> 00:08:16,163
or a reference point for that grade.
136
00:08:17,390 –> 00:08:21,680
Now, the power of Leapfrog’s RBF engine
137
00:08:21,680 –> 00:08:25,780
is in its ability to estimate a quantity
138
00:08:25,780 –> 00:08:29,760
into an unknown point by using known drillhole
139
00:08:29,760 –> 00:08:31,830
or point data.
140
00:08:31,830 –> 00:08:33,540
It’s important however,
141
00:08:33,540 –> 00:08:36,770
that when we estimate those unknown points
142
00:08:36,770 –> 00:08:40,383
that we’re selecting an interpolation function,
143
00:08:40,383 –> 00:08:43,570
that will make the most geological sense.
144
00:08:44,730 –> 00:08:47,220
At this first pass stage,
145
00:08:47,220 –> 00:08:49,732
I hope you’ll agree that we’re seeing something
146
00:08:49,732 –> 00:08:52,110
that’s very unrealistic,
147
00:08:52,110 –> 00:08:56,520
especially in regards to this higher grade sort of blow outs
148
00:08:56,520 –> 00:08:58,263
in my Northwest corner.
149
00:09:00,680 –> 00:09:03,970
It’s fairly common for our projects
150
00:09:03,970 –> 00:09:07,320
to have some areas of data scarcity.
151
00:09:07,320 –> 00:09:09,910
If I bring my drillholes in here,
152
00:09:11,086 –> 00:09:13,393
and just turn the filter off for a second,
153
00:09:17,330 –> 00:09:21,639
then I’m sure you agree that sometimes at depth
154
00:09:21,639 –> 00:09:25,280
or indeed on our last full extents,
155
00:09:25,280 –> 00:09:29,060
that we might just not have any drilling information
156
00:09:29,060 –> 00:09:30,103
in that area.
157
00:09:31,740 –> 00:09:32,960
And in this case,
158
00:09:32,960 –> 00:09:36,852
it is the, it’s just three drillholes here.
159
00:09:36,852 –> 00:09:40,493
If I put my filter on,
160
00:09:42,370 –> 00:09:45,241
you can see that it’s just these three drillholes
161
00:09:45,241 –> 00:09:49,640
that are simply causing that interpolation, here,
162
00:09:49,640 –> 00:09:53,340
to become really quite extrapolated.
163
00:09:53,340 –> 00:09:56,620
And unfortunately there’s many an extreme example in line
164
00:09:56,620 –> 00:09:57,660
of such models
165
00:09:57,660 –> 00:10:01,333
as these finding their way into company reporting.
166
00:10:02,220 –> 00:10:04,890
So what I would encourage you all to do,
167
00:10:04,890 –> 00:10:07,890
is to of course start refining the internal structure
168
00:10:07,890 –> 00:10:11,290
of my model and the majority of the functionality
169
00:10:11,290 –> 00:10:16,290
to do so actually sits under the Interpolant tab.
170
00:10:16,590 –> 00:10:17,640
So if I go to the model
171
00:10:17,640 –> 00:10:20,403
and I’ll go to the one that’s run originally.
172
00:10:22,520 –> 00:10:24,260
So just double-click into it
173
00:10:24,260 –> 00:10:27,133
and I’m going to come to the Interpolant tab.
174
00:10:29,150 –> 00:10:34,150
For now, I’m simply going to change my Interpolant type
175
00:10:34,640 –> 00:10:39,640
to a Spheroidal and change my Drift function to None.
176
00:10:41,240 –> 00:10:43,720
I will come back to this in more detail, but for now,
177
00:10:43,720 –> 00:10:47,380
let me just let that run and we’ll have a look
178
00:10:47,380 –> 00:10:49,553
at what that produces instead.
179
00:10:50,960 –> 00:10:52,220
And again, great,
180
00:10:52,220 –> 00:10:53,803
here’s one I prepared earlier,
181
00:10:58,550 –> 00:11:00,910
which we can now see,
182
00:11:00,910 –> 00:11:02,800
and hopefully you can already see
183
00:11:02,800 –> 00:11:05,630
this big notable difference already,
184
00:11:05,630 –> 00:11:09,060
especially where a high grade
185
00:11:10,130 –> 00:11:13,533
or where that original high-grade was blown out.
186
00:11:15,180 –> 00:11:18,363
This time, if I bring my drillholes back in again,
187
00:11:21,870 –> 00:11:25,677
we can see that high grade interpolation
188
00:11:25,677 –> 00:11:29,310
around those three drillhole still exists,
189
00:11:29,310 –> 00:11:33,013
but just with a much smaller range of influence.
190
00:11:34,040 –> 00:11:38,250
But why is that the case? To help answer that question,
191
00:11:38,250 –> 00:11:42,030
I’m going to try and replicate these RBF and parameters
192
00:11:42,030 –> 00:11:45,290
on a simple 2D grid of points
193
00:11:45,290 –> 00:11:49,850
and this should quite literally help connect the dots
194
00:11:49,850 –> 00:11:52,020
in our 3D picture.
195
00:11:52,020 –> 00:11:54,410
So let me move away from this for a second
196
00:11:54,410 –> 00:11:58,020
and just bring in my grid of points
197
00:11:59,070 –> 00:12:02,760
and a couple of arbitrary samples.
198
00:12:02,760 –> 00:12:07,443
Hopefully you can see those values starting to come through.
199
00:12:11,340 –> 00:12:12,173
Here we go.
200
00:12:14,520 –> 00:12:17,820
So what I’ve done so far for this is,
201
00:12:17,820 –> 00:12:22,820
I have created three new RBF models
202
00:12:24,040 –> 00:12:28,173
in order to estimate these six points shown on screen here.
203
00:12:29,140 –> 00:12:34,140
And then I will come back into each of the Interpolant tabs
204
00:12:34,728 –> 00:12:39,728
in order to adjust the Interpolant and Drift settings.
205
00:12:41,600 –> 00:12:45,243
And that’s just what the naming refers to here.
206
00:12:47,380 –> 00:12:52,380
Now, Leapfrog uses two main interpolant functions,
207
00:12:52,670 –> 00:12:57,530
which in very simple terms will produce different estimates
208
00:12:57,530 –> 00:12:59,190
depending on whether the distance
209
00:12:59,190 –> 00:13:01,308
from our known sample points,
210
00:13:01,308 –> 00:13:05,063
i.e. the range, is taken into consideration.
211
00:13:06,019 –> 00:13:10,360
A linear interpolant will simply assume
212
00:13:10,360 –> 00:13:13,840
that any known values closer to the points
213
00:13:13,840 –> 00:13:15,550
you wish to estimate
214
00:13:15,550 –> 00:13:18,610
we’ll have a proportionally greater influence
215
00:13:18,610 –> 00:13:20,673
than any of those further away.
216
00:13:22,040 –> 00:13:25,480
A spheroidal interpolant on the other hand
217
00:13:25,480 –> 00:13:30,160
assumes that there is a finite range or limit
218
00:13:30,160 –> 00:13:32,700
to the influence of our known data
219
00:13:32,700 –> 00:13:36,141
beyond which this should fall to zero.
220
00:13:36,141 –> 00:13:39,130
You may recognize the resemblance here
221
00:13:39,130 –> 00:13:42,060
to a spherical variogram,
222
00:13:42,060 –> 00:13:45,960
and for the vast majority of metallic ore deposits,
223
00:13:45,960 –> 00:13:49,430
this interpolation type is more applicable.
224
00:13:49,430 –> 00:13:53,240
Exceptions to this, maybe any laterally extensive deposit
225
00:13:53,240 –> 00:13:56,503
like coal or banded iron formations.
226
00:13:57,670 –> 00:14:00,870
So in addition to considering the interpolation method,
227
00:14:00,870 –> 00:14:05,510
we must always also decide how best to control
228
00:14:05,510 –> 00:14:09,308
our estimation in the absence of any data.
229
00:14:09,308 –> 00:14:10,680
In other words,
230
00:14:10,680 –> 00:14:13,510
how should our estimation behave
231
00:14:13,510 –> 00:14:17,490
when we’re past the range of our samples?
232
00:14:17,490 –> 00:14:20,540
Say in the scenario we saw just a minute ago
233
00:14:20,540 –> 00:14:22,483
with those three drillholes.
234
00:14:23,610 –> 00:14:27,140
For this, we need to start defining an appropriate Drift
235
00:14:27,140 –> 00:14:29,240
from the options available.
236
00:14:29,240 –> 00:14:33,300
And I think that was the point that I sort of got into
237
00:14:33,300 –> 00:14:35,340
looking at on my grid.
238
00:14:35,340 –> 00:14:40,340
So at the moment I have a Linear interpolant type
239
00:14:40,670 –> 00:14:42,440
with a Linear Drift shown
240
00:14:43,520 –> 00:14:46,890
and much kind of like the continuous coloured legend
241
00:14:46,890 –> 00:14:48,470
that I have up here,
242
00:14:48,470 –> 00:14:49,560
we’re seeing a linear,
243
00:14:49,560 –> 00:14:52,363
a steady linear trend in our estimation.
244
00:14:54,130 –> 00:14:57,660
The issue is, whilst the estimation around
245
00:14:57,660 –> 00:15:00,497
our known data points is as expected,
246
00:15:00,497 –> 00:15:03,690
the Linear Drift will enable values
247
00:15:03,690 –> 00:15:08,420
to both increase past the highest grade,
248
00:15:08,420 –> 00:15:09,253
so in this case,
249
00:15:09,253 –> 00:15:12,803
we’re sort of upwards to about a grade of 13 here,
250
00:15:13,937 –> 00:15:18,937
as well as go into the negatives past the lowest grade.
251
00:15:21,700 –> 00:15:25,260
So for grade data of this nature,
252
00:15:25,260 –> 00:15:29,010
we’re going to want to reign that estimation in
253
00:15:29,010 –> 00:15:32,653
and start to factor in a range of influence.
254
00:15:34,190 –> 00:15:37,931
So looking now at our spheroidal interpolant
255
00:15:37,931 –> 00:15:41,130
with a Drift of None,
256
00:15:41,130 –> 00:15:44,430
we can see how the range starts to have an influence
257
00:15:44,430 –> 00:15:48,820
on our estimation and then when we move away
258
00:15:48,820 –> 00:15:50,780
from our known values,
259
00:15:50,780 –> 00:15:52,770
so for example, if I start to come out
260
00:15:52,770 –> 00:15:57,770
onto the extents here, then the estimation is falling
261
00:15:57,910 –> 00:16:00,790
or decaying back to zero.
262
00:16:00,790 –> 00:16:02,180
And that will be the same
263
00:16:02,180 –> 00:16:05,000
if I sort of go around any of these,
264
00:16:05,000 –> 00:16:09,338
we would expect to be getting down to a value of zero
265
00:16:09,338 –> 00:16:11,953
away from any data points.
266
00:16:13,760 –> 00:16:16,170
And of course, if you are close to the data point,
267
00:16:16,170 –> 00:16:20,173
we would expect it to be an estimation similar.
268
00:16:21,700 –> 00:16:26,290
So where you’re modelling an unconstrained area,
269
00:16:26,290 –> 00:16:29,770
or perhaps don’t have many low grade holes
270
00:16:29,770 –> 00:16:31,811
to constrain your deposit,
271
00:16:31,811 –> 00:16:34,890
using a Drift of None will ensure
272
00:16:34,890 –> 00:16:38,630
that you have some control on how far your samples
273
00:16:38,630 –> 00:16:40,410
would have an influence.
274
00:16:40,410 –> 00:16:44,500
That said, if you are trying to model something constrained,
275
00:16:44,500 –> 00:16:49,450
for example, the Early Diorite domain that we saw earlier,
276
00:16:49,450 –> 00:16:53,580
then using a Drift function of Constant
277
00:16:54,850 –> 00:16:56,588
could be more applicable.
278
00:16:56,588 –> 00:17:00,480
In this case, our values are reverting
279
00:17:00,480 –> 00:17:03,030
to the approximate mean of the data.
280
00:17:03,030 –> 00:17:08,030
So if I just bring up the statistics, our mean here is 4.167,
281
00:17:12,010 –> 00:17:14,910
which means that as I’m getting to the outskirts,
282
00:17:14,910 –> 00:17:18,960
I would expect it to be coming back towards that mean.
283
00:17:18,960 –> 00:17:22,440
So a few different options, but of course,
284
00:17:22,440 –> 00:17:26,240
different scenarios in how we want to apply these.
285
00:17:26,240 –> 00:17:31,240
Now, if I jump back now to my gold model,
286
00:17:35,070 –> 00:17:36,580
then let’s start first of all,
287
00:17:36,580 –> 00:17:39,513
just with a quick reminder of where we started.
288
00:17:41,280 –> 00:17:43,003
Which was with this model,
289
00:17:44,170 –> 00:17:48,650
and this is applying that default Linear interpolant,
290
00:17:49,530 –> 00:17:54,030
and that simply by changing this already
291
00:17:54,030 –> 00:17:58,360
to the spheroidal interpolant type
292
00:17:58,360 –> 00:18:00,593
along with a Drift of None,
293
00:18:02,010 –> 00:18:04,330
then we’re starting to see something
294
00:18:04,330 –> 00:18:06,653
that makes much more sense.
295
00:18:08,791 –> 00:18:13,791
So if I go back now and go back to my Interpolant tab
296
00:18:15,870 –> 00:18:18,473
to sort of look at some of these other settings.
297
00:18:20,924 –> 00:18:25,924
So far we know we want to limit the influence
298
00:18:27,030 –> 00:18:30,820
of our known data to a certain distance,
299
00:18:30,820 –> 00:18:33,020
and that it’s the distance reign
300
00:18:33,020 –> 00:18:36,243
essentially controlling that correlation.
301
00:18:37,230 –> 00:18:40,110
It’s reasonable, therefore that you’re going to want to,
302
00:18:40,110 –> 00:18:42,610
you’re going to want to change the Base Range
303
00:18:42,610 –> 00:18:44,720
to something more appropriate.
304
00:18:44,720 –> 00:18:46,170
And if you don’t know where to start,
305
00:18:46,170 –> 00:18:49,680
then a rule of thumb could be around twice
306
00:18:49,680 –> 00:18:51,240
the drillhole spacing.
307
00:18:51,240 –> 00:18:55,170
So in this case, let’s up that to around 700,
308
00:18:55,170 –> 00:18:57,393
which is appropriate for this project.
309
00:18:59,350 –> 00:19:04,000
We also want to consider our Nugget and in Leapfrog,
310
00:19:04,000 –> 00:19:07,813
this is expressed as a percentage to our sill.
311
00:19:09,070 –> 00:19:13,640
Increasing the value of the Nugget will create smoother
312
00:19:13,640 –> 00:19:18,640
results by limiting the effects of extreme outliers.
313
00:19:18,660 –> 00:19:21,972
In other words, we would give more emphasis
314
00:19:21,972 –> 00:19:26,190
to the average grades of our surrounding values
315
00:19:26,190 –> 00:19:28,643
and less on the actual data point.
316
00:19:29,490 –> 00:19:32,330
It can basically help to reduce noise
317
00:19:32,330 –> 00:19:34,630
caused by these outliers
318
00:19:34,630 –> 00:19:37,703
or with inaccurately measured samples.
319
00:19:39,090 –> 00:19:43,420
What value to use here is very much decided on a deposit
320
00:19:43,420 –> 00:19:44,780
by deposit case.
321
00:19:44,780 –> 00:19:48,500
And by all means, if you or someone else
322
00:19:48,500 –> 00:19:51,060
in your organisation has already figured this out
323
00:19:52,030 –> 00:19:54,703
for your deposit, then by all means apply it here.
324
00:19:55,570 –> 00:19:58,970
Perhaps for a gold deposit like this
325
00:19:58,970 –> 00:20:02,280
then a rule of thumb will be,
326
00:20:02,280 –> 00:20:05,410
let’s say, 20 to 30% of the Sill.
327
00:20:05,410 –> 00:20:07,170
So let’s just take this down.
328
00:20:07,170 –> 00:20:10,793
For example, it’s 0.2, which is going to be 20% of that
329
00:20:10,793 –> 00:20:14,170
sill I have. 10% might be more appropriate
330
00:20:14,170 –> 00:20:17,400
for other metallic deposits or indeed none,
331
00:20:17,400 –> 00:20:21,560
if you have a very consistent data set.
332
00:20:21,560 –> 00:20:23,733
We’ve spoken about Drift already,
333
00:20:25,220 –> 00:20:29,430
but now that we are past the range of influence,
334
00:20:29,430 –> 00:20:33,520
then it’s really our drift that comes into play.
335
00:20:33,520 –> 00:20:37,220
Using None in this case is going to help
336
00:20:37,220 –> 00:20:41,409
control how far my samples will have an influence
337
00:20:41,409 –> 00:20:45,223
before the estimation decays back to zero.
338
00:20:46,329 –> 00:20:50,140
I’m not going to delve too much
339
00:20:50,140 –> 00:20:51,850
into the other settings here.
340
00:20:51,850 –> 00:20:53,410
You can always read about these
341
00:20:53,410 –> 00:20:55,323
to your heart’s content online,
342
00:20:56,250 –> 00:20:58,720
but the take home point really is that,
343
00:20:58,720 –> 00:21:03,320
it’s the interpolant the Base Range,
344
00:21:03,320 –> 00:21:06,940
that percentage Nugget to the sill and Drift
345
00:21:07,840 –> 00:21:10,480
that will have the most material effects
346
00:21:10,480 –> 00:21:13,400
on your numeric model.
347
00:21:13,400 –> 00:21:16,030
Get these right and you should be well on your way
348
00:21:16,030 –> 00:21:17,970
to producing a robust model
349
00:21:17,970 –> 00:21:21,060
that makes the best of your geological knowledge.
350
00:21:21,060 –> 00:21:24,460
All right, now we’ve talked a little bit about
351
00:21:24,460 –> 00:21:27,310
these interpolant settings.
352
00:21:27,310 –> 00:21:30,706
I thought it would be worth a quick run over
353
00:21:30,706 –> 00:21:33,750
on the Isosurfaces.
354
00:21:33,750 –> 00:21:35,860
So we can see all these,
355
00:21:35,860 –> 00:21:39,530
as we expand out our numeric model objects,
356
00:21:39,530 –> 00:21:41,520
we’ve got Isosurfaces
357
00:21:41,520 –> 00:21:45,420
and then of course the resulting Output Volumes.
358
00:21:45,420 –> 00:21:50,020
When we pick cutoffs in our Outputs tab,
359
00:21:50,020 –> 00:21:54,047
we are simply asking Leapfrog to define some boundaries
360
00:21:54,047 –> 00:21:56,990
in space, i.e. contours,
361
00:21:56,990 –> 00:22:00,520
where there is the same consistent grade.
362
00:22:00,520 –> 00:22:05,520
Essentially the Isosurfaces perform the exact same task
363
00:22:05,910 –> 00:22:08,696
as our geological surfaces do
364
00:22:08,696 –> 00:22:10,776
when we’re geologically modeling.
365
00:22:10,776 –> 00:22:14,690
But instead of building these surfaces ourselves,
366
00:22:14,690 –> 00:22:17,051
we’re simply picking grade boundaries
367
00:22:17,051 –> 00:22:20,330
that we want to see and Leapfrog will go
368
00:22:20,330 –> 00:22:21,973
and build them for us.
369
00:22:23,250 –> 00:22:26,343
It is this contour surface that,
370
00:22:26,343 –> 00:22:29,770
that we’re seeing here in 3D.
371
00:22:29,770 –> 00:22:34,020
And if we want to visualise a specific value,
372
00:22:34,020 –> 00:22:38,857
then we can do so by updating the Iso Values here.
373
00:22:40,760 –> 00:22:44,850
Before I do that, let me just jump back
374
00:22:44,850 –> 00:22:46,980
into the grid of points,
375
00:22:46,980 –> 00:22:51,430
just to highlight this on a sort of simpler dataset.
376
00:22:53,947 –> 00:22:58,810
So back in with my grid of points, let’s say for instance,
377
00:22:58,810 –> 00:23:03,350
I now want to visualise a contour surface
378
00:23:03,350 –> 00:23:07,612
with a grade of two, then I can replicate that here
379
00:23:07,612 –> 00:23:12,049
simply by setting some appropriate value filters.
380
00:23:12,049 –> 00:23:14,520
And we can see that now
381
00:23:14,520 –> 00:23:18,746
sort of finding all of those sort of values of two in space.
382
00:23:18,746 –> 00:23:22,840
And these it’s this point that of course
383
00:23:22,840 –> 00:23:25,263
is going to become our contour.
384
00:23:27,900 –> 00:23:29,401
For the hikers amongst us
385
00:23:29,401 –> 00:23:32,550
who are maybe used to seeing elevation contour lines
386
00:23:32,550 –> 00:23:33,850
on a 2D map
387
00:23:33,850 –> 00:23:35,492
this is the same principle,
388
00:23:35,492 –> 00:23:38,180
except in the case of our gold model,
389
00:23:38,180 –> 00:23:41,803
we’re simply looking at a value representation in 3D.
390
00:23:43,060 –> 00:23:48,060
So let me go back to my gold model once again
391
00:23:49,690 –> 00:23:54,690
and actually set some better Iso Values for this deposit.
392
00:23:57,710 –> 00:23:59,960
So am just going to go double-click back in
393
00:23:59,960 –> 00:24:02,870
and head over to the Output tab.
394
00:24:02,870 –> 00:24:06,670
So let’s just set a few, make a little bit more sense
395
00:24:06,670 –> 00:24:10,900
than the ones that are put in as default.
396
00:24:10,900 –> 00:24:14,663
So let’s say 0.5, 0.75,
397
00:24:16,350 –> 00:24:21,350
let’s do a 1, a 1.25 and a 1.5, I think we’ll suffice.
398
00:24:27,970 –> 00:24:29,640
The other thing that I’m going to do
399
00:24:29,640 –> 00:24:33,990
is take down the resolution on my higher grades
400
00:24:33,990 –> 00:24:37,023
to try and be as accurate as possible.
401
00:24:38,190 –> 00:24:41,360
And remembering to know you might not have heard it,
402
00:24:41,360 –> 00:24:43,650
but remembering my much earlier points
403
00:24:43,650 –> 00:24:46,010
about matching this where possible
404
00:24:46,010 –> 00:24:48,500
to the drillhole composite lengths.
405
00:24:48,500 –> 00:24:51,963
So that’s why I’m sort of picking the six here.
406
00:24:53,500 –> 00:24:58,500
There’s also the ability in this tab to clamp output values,
407
00:24:59,740 –> 00:25:02,610
the default assumption is that
408
00:25:02,610 –> 00:25:04,320
nothing should fall below zero,
409
00:25:04,320 –> 00:25:07,151
which is why we’re seeing that clamp,
410
00:25:07,151 –> 00:25:11,440
but you can always change that if need be likewise,
411
00:25:11,440 –> 00:25:13,763
you can set different Lower,
412
00:25:14,710 –> 00:25:19,280
and indeed Upper bounds in the Value Transform tab
413
00:25:19,280 –> 00:25:22,373
to cap any values you may deem too low or too high,
414
00:25:23,360 –> 00:25:26,803
but I’m not going to focus on that for now.
415
00:25:28,110 –> 00:25:31,230
So let me just let that run
416
00:25:37,030 –> 00:25:42,030
and again, in the magic of Leapfrog,
417
00:25:42,510 –> 00:25:46,940
so have a look at, so what that has produced,
418
00:25:46,940 –> 00:25:50,630
and again, we’re starting to see something visually
419
00:25:50,630 –> 00:25:52,710
that perhaps makes more sense.
420
00:25:52,710 –> 00:25:57,033
That makes more sense to us and to our gold boundaries.
421
00:25:58,990 –> 00:26:03,010
Now, if I want to see more connectivity
422
00:26:03,010 –> 00:26:07,550
between my drillholes, then aside from the Base Range,
423
00:26:07,550 –> 00:26:09,630
I could use a trend for this.
424
00:26:09,630 –> 00:26:14,630
Also the central shear zone, for example,
425
00:26:15,720 –> 00:26:20,720
is no doubt playing a dominant structural control
426
00:26:21,870 –> 00:26:23,750
on my mineralisation.
427
00:26:23,750 –> 00:26:25,490
Starting to see a lot of our high grades,
428
00:26:25,490 –> 00:26:28,463
sort of following some sort of trend here.
429
00:26:29,370 –> 00:26:32,400
So applying a structural trend should help
430
00:26:32,400 –> 00:26:36,409
to account for any changes in the strength
431
00:26:36,409 –> 00:26:40,313
and direction of continuity along this ridge.
432
00:26:41,330 –> 00:26:45,373
I’ve already defined a Structural Trend for the shear zone.
433
00:26:46,230 –> 00:26:49,173
I sort of put it as something like this for now.
434
00:26:51,130 –> 00:26:55,410
However we could of course always update this as need be.
435
00:26:55,410 –> 00:26:58,640
Either way, this is a typical step to take
436
00:26:58,640 –> 00:27:02,243
given that nature is very rarely isotropic.
437
00:27:03,530 –> 00:27:08,530
So let me go and apply this Structural Trend to my model
438
00:27:11,960 –> 00:27:15,403
and which I can do from my Trend tab.
439
00:27:17,790 –> 00:27:20,220
And I’ve only got the one in my project at the moment,
440
00:27:20,220 –> 00:27:22,353
So it’s just that Structural Trend,
441
00:27:25,240 –> 00:27:26,793
and let’s just let that run.
442
00:27:34,000 –> 00:27:39,000
And again, in a fantastic here’s one I prepared earlier,
443
00:27:43,430 –> 00:27:45,370
we can see what that has done
444
00:27:45,370 –> 00:27:49,870
this definitely you can see how that trend has changed
445
00:27:49,870 –> 00:27:52,780
there is weighting of points in space
446
00:27:52,780 –> 00:27:57,550
to define that continuity along that ridge.
447
00:27:57,550 –> 00:28:01,560
So though powerful and usually very applicable
448
00:28:01,560 –> 00:28:05,776
certainly in our sort of metallic gold
449
00:28:05,776 –> 00:28:08,653
or indeed any deposit.
450
00:28:09,970 –> 00:28:13,843
So now that we’ve sort of run to this point,
451
00:28:14,870 –> 00:28:17,030
it’s likely at this stage
452
00:28:17,030 –> 00:28:21,590
that we’re going to want to hone in our mineralised domains.
453
00:28:21,590 –> 00:28:26,147
I spoke earlier about the Early Diorite unit
454
00:28:27,780 –> 00:28:31,650
having our – containing our – highest mean gold grade.
455
00:28:31,650 –> 00:28:36,439
So let’s come full circle and create a Numeric model
456
00:28:36,439 –> 00:28:38,793
for just this volume also.
457
00:28:41,430 –> 00:28:46,430
So let me clear the scene and let me cheat
458
00:28:48,370 –> 00:28:51,640
by copying my last model
459
00:28:51,640 –> 00:28:54,760
with all of its parameters into the new one.
460
00:29:05,230 –> 00:29:10,230
And now we can go into that copy of our model
461
00:29:11,880 –> 00:29:16,750
and start to apply reasonable premises here as well.
462
00:29:16,750 –> 00:29:20,060
Now, the first thing we’re going to want to do is of course,
463
00:29:20,060 –> 00:29:21,470
set some boundary at the moment
464
00:29:21,470 –> 00:29:25,900
it’s just the exact same as the last one,
465
00:29:25,900 –> 00:29:30,760
which is the extents of my geological model.
466
00:29:30,760 –> 00:29:34,830
Say, let’s go in and set a New Lateral Extent.
467
00:29:34,830 –> 00:29:37,971
And what I’m going to do is use the volume
468
00:29:37,971 –> 00:29:41,290
for my geological model as that extent.
469
00:29:41,290 –> 00:29:46,290
Say from surface, and then under my geological models,
470
00:29:48,370 –> 00:29:50,200
under the Output Volumes,
471
00:29:50,200 –> 00:29:52,903
I’m going to select that Early Diorite.
472
00:29:57,230 –> 00:29:59,920
Now, whilst that’s running
473
00:29:59,920 –> 00:30:02,960
remember that what that is going to do
474
00:30:02,960 –> 00:30:06,710
is first of all, constrain your model
475
00:30:06,710 –> 00:30:08,340
to that unit of interest.
476
00:30:08,340 –> 00:30:10,043
So this is my Early Diorite.
477
00:30:12,530 –> 00:30:17,530
And it’s also just only going to use the values
478
00:30:22,910 –> 00:30:26,320
that refer to this unit,
479
00:30:26,320 –> 00:30:29,700
what to do with that initial surface filter set up.
480
00:30:29,700 –> 00:30:30,533
We then of course
481
00:30:30,533 –> 00:30:34,120
want to go and review our interpolant settings here
482
00:30:34,120 –> 00:30:35,693
to check that they’re still applicable
483
00:30:35,693 –> 00:30:39,303
now that we’ve constrained our data to one domain.
484
00:30:40,740 –> 00:30:45,740
Let me say, let me go back and double-click into this model.
485
00:30:46,240 –> 00:30:47,788
And let’s just double check once again,
486
00:30:47,788 –> 00:30:51,493
that our interpolant settings make sense.
487
00:30:52,570 –> 00:30:57,410
It’s probably going to be more applicable in this case
488
00:30:58,635 –> 00:31:01,290
that where we have an absence of data,
489
00:31:01,290 –> 00:31:06,213
so again, on the outskirts, on the extents of our model,
490
00:31:08,460 –> 00:31:10,730
that perhaps we’re going to want to revert
491
00:31:10,730 –> 00:31:13,610
to the mean of the grade in the absence
492
00:31:13,610 –> 00:31:15,103
of any other information.
493
00:31:16,110 –> 00:31:19,030
In which case, the best thing that we can do
494
00:31:19,030 –> 00:31:23,890
is simply to update the Drift here to Constant.
495
00:31:23,890 –> 00:31:26,570
Hopefully you remember from that grid of points,
496
00:31:26,570 –> 00:31:31,200
how that is always going to revert to the mean of the data.
497
00:31:31,200 –> 00:31:32,740
I think for now,
498
00:31:32,740 –> 00:31:35,460
I’m just going to leave every other setting the same,
499
00:31:35,460 –> 00:31:37,630
but of course we could come in
500
00:31:37,630 –> 00:31:41,270
and start to change any of these,
501
00:31:41,270 –> 00:31:44,340
if we wish to see things a little bit differently,
502
00:31:44,340 –> 00:31:47,070
but for now, it’s that drift that for me
503
00:31:47,070 –> 00:31:48,570
is the most important.
504
00:31:48,570 –> 00:31:53,147
So again, let me rerun and bring in a final output.
505
00:32:02,240 –> 00:32:06,520
And if I just make these a little less transparent,
506
00:32:06,520 –> 00:32:08,230
you can hopefully see now
507
00:32:08,230 –> 00:32:13,230
that whereas before we had sort of that those waste grades
508
00:32:14,230 –> 00:32:17,260
coming in on this sort of bottom corner,
509
00:32:17,260 –> 00:32:19,500
we’re now reverting
510
00:32:19,500 –> 00:32:23,330
to something similar to the mean and I think in this case,
511
00:32:23,330 –> 00:32:25,630
if I remember rightly the mean is yeah, 1.151.
512
00:32:29,272 –> 00:32:33,130
So we would expect to be kind of up in that sort of darker,
513
00:32:33,130 –> 00:32:34,433
darker yellow colours.
514
00:32:38,020 –> 00:32:39,620
At this point,
515
00:32:39,620 –> 00:32:42,230
I’m going to say that I’m reasonably happy
516
00:32:42,230 –> 00:32:43,793
with the models I have.
517
00:32:44,720 –> 00:32:47,900
I would, of course, want to interrogate these lot further,
518
00:32:47,900 –> 00:32:50,502
maybe make some manual edits
519
00:32:50,502 –> 00:32:53,578
or double check some of the input data,
520
00:32:53,578 –> 00:32:55,490
but for the purpose of this talk,
521
00:32:55,490 –> 00:32:57,910
I hope that this has gone some way
522
00:32:57,910 –> 00:33:01,090
in highlighting which interpolant settings
523
00:33:01,090 –> 00:33:04,984
will most effectively improve your Numeric Models.
524
00:33:04,984 –> 00:33:08,450
I appreciate that this is a very extensive topic
525
00:33:08,450 –> 00:33:10,550
to try and fit into a shorter amount of time.
526
00:33:10,550 –> 00:33:13,223
Please do keep your questions coming in.
527
00:33:14,090 –> 00:33:15,130
In the meantime,
528
00:33:15,130 –> 00:33:19,030
I’m going to hand over to James now,
529
00:33:19,030 –> 00:33:23,550
to run us through the Indicator RBF Interpolant tool.
530
00:33:24,550 –> 00:33:25,730
<v James>Thanks, Suzanna,</v>
531
00:33:25,730 –> 00:33:28,850
bear with me two seconds and I’ll just share my screen.
532
00:33:28,850 –> 00:33:32,350
So a lot of the stuff that Suzanna has run through
533
00:33:32,350 –> 00:33:34,830
in those settings, we’re going to apply now
534
00:33:34,830 –> 00:33:37,620
to the Indicator Numeric Models.
535
00:33:38,520 –> 00:33:41,530
Indicator Numeric Models are a tool
536
00:33:41,530 –> 00:33:46,220
that is often underused or overlooked in preference
537
00:33:46,220 –> 00:33:47,810
to the RBF models,
538
00:33:47,810 –> 00:33:51,480
but Indicator Models can have a really valuable place
539
00:33:51,480 –> 00:33:52,923
in anyone’s workflow.
540
00:33:53,870 –> 00:33:55,910
So I’ve got the same project here,
541
00:33:55,910 –> 00:33:58,050
but this time I’m going to be looking at
542
00:33:58,050 –> 00:34:02,120
some of the copper grades that we have in the project.
543
00:34:02,120 –> 00:34:06,310
If I go into a bit of analysis initially on my data,
544
00:34:06,310 –> 00:34:09,968
I can see that when I look at the statistics for my copper,
545
00:34:09,968 –> 00:34:14,968
there isn’t really a dominant trend to the geology
546
00:34:16,350 –> 00:34:19,879
and where my copper is hosted is more of a disseminated
547
00:34:19,879 –> 00:34:24,480
mineralization that is spread across multiple domains.
548
00:34:24,480 –> 00:34:27,600
If I come in and have a look at the copper itself,
549
00:34:27,600 –> 00:34:29,250
what I want to try and understand
550
00:34:30,170 –> 00:34:34,740
is what it would be a good cutoff to apply
551
00:34:34,740 –> 00:34:37,580
when I’m trying to use my indicator models
552
00:34:37,580 –> 00:34:38,650
and this case here,
553
00:34:38,650 –> 00:34:42,470
I’ve had a look at the histogram of the log,
554
00:34:42,470 –> 00:34:44,380
and there’s many different ways
555
00:34:44,380 –> 00:34:46,954
that you can approach cutoffs.
556
00:34:46,954 –> 00:34:49,440
But in this case, I’m looking for breaks
557
00:34:49,440 –> 00:34:51,640
in the natural distribution of the data.
558
00:34:51,640 –> 00:34:54,600
And for today, I’m going to pick one around this area
559
00:34:54,600 –> 00:34:56,593
where I see this kind of step change
560
00:34:56,593 –> 00:34:58,573
in my grade distribution.
561
00:34:59,410 –> 00:35:00,900
So at this point here,
562
00:35:00,900 –> 00:35:05,900
I can see that I’m somewhere between 0.28 and 0.31% copper.
563
00:35:06,770 –> 00:35:09,950
So for the purpose of the exercise,
564
00:35:09,950 –> 00:35:13,553
we’ll walk through today we’ll use 0.3 as my cutoff.
565
00:35:15,051 –> 00:35:18,210
So once I’ve had a look at my data and I have a better idea
566
00:35:18,210 –> 00:35:19,660
of the kind of cutoffs
567
00:35:19,660 –> 00:35:23,020
I want to use to identify mineralization,
568
00:35:23,020 –> 00:35:25,773
I can come down to my Numeric Models folder,
569
00:35:26,720 –> 00:35:30,710
right-click to create a New Indicator
570
00:35:30,710 –> 00:35:31,910
Interpolant.
571
00:35:34,186 –> 00:35:38,073
The layout to this is very similar to the Numeric Modelling.
572
00:35:39,010 –> 00:35:39,843
Again, you can see,
573
00:35:39,843 –> 00:35:43,050
that I can specify the values I want to use.
574
00:35:43,050 –> 00:35:45,090
I can pick the boundaries I want to apply.
575
00:35:45,090 –> 00:35:48,700
So for now, I’m just going to use the total project
576
00:35:48,700 –> 00:35:49,533
and all my data.
577
00:35:51,420 –> 00:35:53,730
And if I want to apply my query filters,
578
00:35:53,730 –> 00:35:55,080
I can do that here as well.
579
00:35:56,086 –> 00:35:58,670
A couple of other steps I need to do,
580
00:35:58,670 –> 00:36:00,820
because this is an Indicator Interpolant.
581
00:36:00,820 –> 00:36:02,730
I need to apply a cutoff.
582
00:36:02,730 –> 00:36:03,590
So what I’m doing here is
583
00:36:03,590 –> 00:36:05,960
I’m trying to create a single surface
584
00:36:05,960 –> 00:36:10,513
in closing grades above my cutoff of 0.3.
585
00:36:11,840 –> 00:36:13,240
And for the purpose of time,
586
00:36:13,240 –> 00:36:16,490
I’m also going to just composite my data here.
587
00:36:16,490 –> 00:36:18,710
So that it helps to run,
588
00:36:18,710 –> 00:36:22,770
but it also helps to standardise my data.
589
00:36:22,770 –> 00:36:26,400
So I’m going to set my composite length to four
590
00:36:26,400 –> 00:36:29,240
and anywhere where I have residual lengths less than one,
591
00:36:29,240 –> 00:36:31,990
I’m going to distribute those equally back through my data.
592
00:36:33,950 –> 00:36:36,093
I can give it a name to help me identify it.
593
00:36:37,350 –> 00:36:38,500
And we’re going to come back
594
00:36:38,500 –> 00:36:42,603
and talk about the Iso values in a minute.
595
00:36:43,520 –> 00:36:45,338
So for now, I’m going to leave my Iso value
596
00:36:45,338 –> 00:36:49,003
as a default of 0.5, and then I can let that run.
597
00:36:52,460 –> 00:36:55,580
So what Leapfrog does with the indicators
598
00:36:55,580 –> 00:36:58,090
is it will create two volumes.
599
00:36:58,090 –> 00:37:02,150
It creates a volume that is considered inside my cutoff.
600
00:37:02,150 –> 00:37:05,093
So if I expand my model down here,
601
00:37:06,440 –> 00:37:08,800
we’ll see there’s two volumes as the output.
602
00:37:08,800 –> 00:37:11,960
So there’s one that is above my cutoff,
603
00:37:11,960 –> 00:37:12,960
which is this volume.
604
00:37:12,960 –> 00:37:15,890
And one that is below my cutoff,
605
00:37:15,890 –> 00:37:17,290
which is the Outside volume.
606
00:37:19,775 –> 00:37:20,690
Now, at the moment,
607
00:37:20,690 –> 00:37:23,560
those shapes are not particularly realistic.
608
00:37:23,560 –> 00:37:25,330
Again, very similar to what we saw
609
00:37:25,330 –> 00:37:28,720
with Suzanna’s explanation initially
610
00:37:28,720 –> 00:37:30,100
because of the settings I’m using,
611
00:37:30,100 –> 00:37:32,853
I’m getting these blow outs to the extent of my models.
612
00:37:35,020 –> 00:37:36,388
The other thing we can have a quick look at
613
00:37:36,388 –> 00:37:38,940
before we go and change any of the settings
614
00:37:38,940 –> 00:37:42,550
is how Leapfrog manages the data
615
00:37:42,550 –> 00:37:45,050
that we’ve used in this Indicator.
616
00:37:45,050 –> 00:37:46,850
So it’s taken all of my copper values
617
00:37:46,850 –> 00:37:49,340
and I’ve got my data here in my models.
618
00:37:49,340 –> 00:37:50,563
So if I track that on,
619
00:37:54,503 –> 00:37:56,253
just set that up so you can see it.
620
00:37:57,690 –> 00:38:01,310
So initially from my copper values,
621
00:38:01,310 –> 00:38:04,230
Leapfrog will go and flag all of the data
622
00:38:04,230 –> 00:38:07,060
as either being above or below my cutoff.
623
00:38:07,060 –> 00:38:09,270
So here you can see my cutoff.
624
00:38:09,270 –> 00:38:10,670
So everything above or below.
625
00:38:12,420 –> 00:38:15,870
It’s then going to give me a bit of an analysis
626
00:38:15,870 –> 00:38:18,130
around the grouping of my data.
627
00:38:18,130 –> 00:38:22,570
So here you can see that it looks at the grades
628
00:38:22,570 –> 00:38:25,060
and it looks at the volumes it’s created,
629
00:38:25,060 –> 00:38:28,870
and it will give me a summary of samples
630
00:38:28,870 –> 00:38:32,477
that are above my cutoff and fall inside my volume,
631
00:38:32,477 –> 00:38:35,080
but also samples that are below my cutoff
632
00:38:35,080 –> 00:38:36,673
that are still included inside.
633
00:38:37,510 –> 00:38:38,530
So we can see over here,
634
00:38:38,530 –> 00:38:41,780
these green samples would be an example
635
00:38:43,010 –> 00:38:45,977
where a sample is below my cutoff,
636
00:38:45,977 –> 00:38:48,433
but has been included within that shell.
637
00:38:49,360 –> 00:38:51,200
And essentially this is the equivalent
638
00:38:51,200 –> 00:38:52,110
of things like dilution.
639
00:38:52,110 –> 00:38:55,130
So we’ve got some internal dilution of these waste grades
640
00:38:55,130 –> 00:38:59,210
and equally outside of my Indicator volume,
641
00:38:59,210 –> 00:39:04,210
I have some samples here that fall above my cutoff grade,
642
00:39:04,290 –> 00:39:06,240
but because they’re just isolated samples,
643
00:39:06,240 –> 00:39:08,610
they’ve been excluded from my volume.
644
00:39:08,610 –> 00:39:12,683
So with that data and with that known information,
645
00:39:13,800 –> 00:39:16,160
I then need to go back into my Indicator
646
00:39:16,160 –> 00:39:18,671
and have a look at the parameters and the settings
647
00:39:18,671 –> 00:39:20,910
that I’ve used to see if they’ve been optimised
648
00:39:20,910 –> 00:39:22,610
for the model I’m trying to build.
649
00:39:23,820 –> 00:39:25,880
What we know with our settings,
650
00:39:25,880 –> 00:39:28,480
and again, when we have a look at the Inside volume,
651
00:39:29,840 –> 00:39:32,327
if I come into my Indicator here,
652
00:39:32,327 –> 00:39:34,777
and go and have a look at the settings I’m using,
653
00:39:35,726 –> 00:39:39,260
then I come to the Interpolant tab.
654
00:39:39,260 –> 00:39:42,740
And for the reasons that Suzanna has already run through,
655
00:39:42,740 –> 00:39:45,950
I know when modelling numeric data
656
00:39:45,950 –> 00:39:48,020
and particularly any type of grade data,
657
00:39:48,020 –> 00:39:50,544
I don’t want to be using a Linear interpolant.
658
00:39:50,544 –> 00:39:51,587
I should be using my Spheroidal interpolant.
659
00:39:54,157 –> 00:39:57,380
The other thing I want to go and look at change in is that
660
00:39:57,380 –> 00:40:00,410
I don’t have any constraints on my data at the moment.
661
00:40:00,410 –> 00:40:02,950
So I’ve just used the model boundaries.
662
00:40:02,950 –> 00:40:06,410
So I want to set my Drift to None.
663
00:40:06,410 –> 00:40:09,060
So again, there’s more of a conservative approach
664
00:40:09,060 –> 00:40:10,207
as I’m moving away from data
665
00:40:10,207 –> 00:40:14,523
and my assumption is my grade is reverting to zero.
666
00:40:16,860 –> 00:40:20,090
We can also come and have a look at the volumes.
667
00:40:20,090 –> 00:40:23,020
So currently our Iso value is five.
668
00:40:23,020 –> 00:40:25,340
So we’ll come and talk about that in a second.
669
00:40:25,340 –> 00:40:26,920
And the other good thing we can do here is
670
00:40:26,920 –> 00:40:31,130
we can discard any small volumes.
671
00:40:31,130 –> 00:40:33,670
So as an example of what that means,
672
00:40:33,670 –> 00:40:36,693
if I take a section through my project,
673
00:40:40,000 –> 00:40:41,440
we can see that as we move through,
674
00:40:41,440 –> 00:40:44,910
we get quite a few internal volumes
675
00:40:44,910 –> 00:40:47,920
that aren’t really going to be of much use to us.
676
00:40:47,920 –> 00:40:52,690
So I can filter these out based on a set cutoff.
677
00:40:52,690 –> 00:40:53,523
So in this case,
678
00:40:53,523 –> 00:40:56,293
I’m excluding everything less than 100,000 units,
679
00:40:57,540 –> 00:40:59,450
and I can check my other settings to make sure
680
00:40:59,450 –> 00:41:00,720
that everything else I’m doing,
681
00:41:00,720 –> 00:41:04,533
maybe I used the topography is all set up to run how I want.
682
00:41:05,480 –> 00:41:07,018
Again, what Suzanna talked about,
683
00:41:07,018 –> 00:41:11,055
was there any time that you you’re modelling numeric data
684
00:41:11,055 –> 00:41:14,180
best practice would be to typically use
685
00:41:14,180 –> 00:41:16,560
some form of trend to your data
686
00:41:16,560 –> 00:41:18,460
so I can apply the Structural Trend here
687
00:41:18,460 –> 00:41:22,633
that’s Susanna had in hers, and I can let that one run.
688
00:41:24,400 –> 00:41:26,100
Now, when that’s finished running,
689
00:41:27,700 –> 00:41:30,063
I’ve got my examples here.
690
00:41:31,800 –> 00:41:33,853
So if I load this one on,
691
00:41:36,320 –> 00:41:39,240
I can see the outline here of my updated model
692
00:41:39,240 –> 00:41:43,623
and how that’s changed the shape of my Indicator volume.
693
00:41:44,810 –> 00:41:49,810
So if we come back out of my section, put these back on.
694
00:41:54,160 –> 00:41:56,410
I can see by applying those,
695
00:41:56,410 –> 00:41:58,270
simply by applying those additional parameters,
696
00:41:58,270 –> 00:42:01,060
So changing my interpolant type from Linear
697
00:42:01,060 –> 00:42:03,510
to Spheroidal, adding a Drift of None
698
00:42:03,510 –> 00:42:06,830
and my Structural Trend,
699
00:42:06,830 –> 00:42:08,620
I’ve got a much more realistic shape now
700
00:42:08,620 –> 00:42:12,460
of what is the potential volume of copper
701
00:42:12,460 –> 00:42:13,973
greater than 0.3%.
702
00:42:17,320 –> 00:42:19,250
Now, the next step into this
703
00:42:19,250 –> 00:42:20,930
is to look at those Iso values
704
00:42:20,930 –> 00:42:22,883
and what they actually do to my models,
705
00:42:23,900 –> 00:42:27,030
the ISO value and if we come into the settings here,
706
00:42:28,322 –> 00:42:31,030
so I’m just going to open up the settings again.
707
00:42:31,030 –> 00:42:34,140
You can see at the end, I can set an Iso value.
708
00:42:34,140 –> 00:42:39,140
This is a probability of how many samples within my volume
709
00:42:39,280 –> 00:42:41,830
are going to be above my cutoff.
710
00:42:41,830 –> 00:42:44,380
So essentially if I took a sample
711
00:42:44,380 –> 00:42:46,230
anywhere within this volume,
712
00:42:46,230 –> 00:42:48,690
currently there is a 50% chance that,
713
00:42:48,690 –> 00:42:52,853
that sample would be above my 0.3% copper cutoff.
714
00:42:53,871 –> 00:42:58,860
So by tweaking those Indicator Iso values,
715
00:42:58,860 –> 00:43:01,760
you actually can change the way the model is being built
716
00:43:01,760 –> 00:43:06,760
based on a probability factor of how many,
717
00:43:07,110 –> 00:43:08,940
what’s the chance of those samples
718
00:43:08,940 –> 00:43:10,773
inside being above your cutoff.
719
00:43:12,020 –> 00:43:15,190
So I’ve created two more with identical settings,
720
00:43:15,190 –> 00:43:17,693
but just changed the Iso value on each one.
721
00:43:18,710 –> 00:43:23,133
If we step back into the model, as on a section.
722
00:43:26,640 –> 00:43:28,600
So here we can see our model
723
00:43:28,600 –> 00:43:30,960
which I’m going to take the triangulations off,
724
00:43:30,960 –> 00:43:32,323
so we’ve got the outline.
725
00:43:33,320 –> 00:43:36,650
So currently with this volume,
726
00:43:36,650 –> 00:43:39,497
what I’m saying is that I have a 50% chance
727
00:43:39,497 –> 00:43:41,780
that if I take a sample, anywhere in here,
728
00:43:41,780 –> 00:43:43,400
it is going to be above my cutoff.
729
00:43:44,810 –> 00:43:49,810
I can also change my drillholes here to reflect that cutoff.
730
00:43:49,810 –> 00:43:52,460
So you can see here, 0.3% cutoff,
731
00:43:52,460 –> 00:43:55,470
so you can see all my drilling samples
732
00:43:55,470 –> 00:43:56,720
that are above and below.
733
00:43:58,840 –> 00:44:01,000
If I go into my parameters
734
00:44:01,000 –> 00:44:04,683
and I change my Iso value down to 0.3.
735
00:44:06,060 –> 00:44:08,760
So we can have a look at the inside value on this one.
736
00:44:10,790 –> 00:44:12,890
What this is saying, and I just made some,
737
00:44:12,890 –> 00:44:13,810
so you can see it as well,
738
00:44:13,810 –> 00:44:15,930
is basically, this is a volume
739
00:44:15,930 –> 00:44:18,830
that is more of a prioritisation around volume.
740
00:44:18,830 –> 00:44:20,130
So this could be an example
741
00:44:20,130 –> 00:44:23,677
if you needed to produce a min case and a max case
742
00:44:23,677 –> 00:44:25,150
and a mid case,
743
00:44:25,150 –> 00:44:28,620
then you could do this pretty quickly by using your cutoffs
744
00:44:28,620 –> 00:44:31,620
and using your Iso values.
745
00:44:31,620 –> 00:44:33,940
So drop in an Iso value down to 0.3
746
00:44:35,120 –> 00:44:38,130
is essentially saying that there’s a 30% confidence
747
00:44:38,130 –> 00:44:41,240
that if I take a sample inside this volume,
748
00:44:41,240 –> 00:44:43,240
it will be above my cutoff.
749
00:44:43,240 –> 00:44:45,960
So you can see that changing the Iso value
750
00:44:45,960 –> 00:44:47,300
and keeping everything else the same
751
00:44:47,300 –> 00:44:50,640
has given me a more optimistic volume
752
00:44:50,640 –> 00:44:51,883
for my Indicator shell.
753
00:44:53,180 –> 00:44:57,493
Conversely, if I change my Indicator Iso value to 0.7,
754
00:44:58,780 –> 00:45:00,660
it’s going to be a more conservative shell.
755
00:45:00,660 –> 00:45:05,660
So here, if I have a look at the Inside volume in green,
756
00:45:06,150 –> 00:45:07,740
and again, maybe just to help highlight
757
00:45:07,740 –> 00:45:09,090
the differences with these.
758
00:45:11,100 –> 00:45:15,220
So now this is my, exactly the same settings,
759
00:45:15,220 –> 00:45:18,260
but applying a Iso value,
760
00:45:18,260 –> 00:45:21,183
so a probability or a confidence of 0.7.
761
00:45:22,070 –> 00:45:24,730
And again, just to, for you to review the notes,
762
00:45:24,730 –> 00:45:28,640
so increase in my ISO value
763
00:45:28,640 –> 00:45:30,773
will give me a more conservative case.
764
00:45:31,720 –> 00:45:34,500
This will be prioritising the metal content,
765
00:45:34,500 –> 00:45:36,520
so less dilution
766
00:45:36,520 –> 00:45:38,720
and essentially I can look at those numbers and say,
767
00:45:38,720 –> 00:45:42,700
I have a 70% confidence that any sample inside that volume
768
00:45:42,700 –> 00:45:44,213
769
00:45:47,020 –> 00:45:48,520
So that’s very quickly,
770
00:45:48,520 –> 00:45:50,610
and particularly in the exploration field,
771
00:45:50,610 –> 00:45:53,700
you can have a look at a resource or a volume
772
00:45:53,700 –> 00:45:56,300
and if you want to have a look at a bit of a range analysis
773
00:45:56,300 –> 00:45:58,500
of the potential of your mineralisation,
774
00:45:58,500 –> 00:46:03,340
you can generate your cutoff and then change your ISO values
775
00:46:03,340 –> 00:46:05,933
to give you an idea of how that can work.
776
00:46:07,220 –> 00:46:08,090
Once you’ve built these,
777
00:46:08,090 –> 00:46:10,050
you can also then come in and have a look at the,
778
00:46:10,050 –> 00:46:12,830
it gives you a summary of your statistics.
779
00:46:12,830 –> 00:46:16,040
So if we have a look here at the Indicator at 0.3,
780
00:46:16,040 –> 00:46:18,913
I look at the statistics of the Indicator at 0.7,
781
00:46:22,254 –> 00:46:23,704
we can go down to the Volume.
782
00:46:24,840 –> 00:46:27,610
So you can see the Volume here
783
00:46:27,610 –> 00:46:30,360
for my conservative Iso value at 0.7
784
00:46:31,900 –> 00:46:34,640
is 431 million cubic meters,
785
00:46:34,640 –> 00:46:39,393
as opposed to my optimistic shell, at 545.
786
00:46:40,330 –> 00:46:42,350
You can also see from the number of parts,
787
00:46:42,350 –> 00:46:43,840
so the number of different volumes
788
00:46:43,840 –> 00:46:48,310
that make up those indicator shells in the optimistic one,
789
00:46:48,310 –> 00:46:50,930
I only have one large volume,
790
00:46:50,930 –> 00:46:54,520
whereas the 0.7 is obviously a bit more complex
791
00:46:54,520 –> 00:46:55,983
and has seven parts to it.
792
00:46:57,314 –> 00:46:59,190
The last thing you can do
793
00:46:59,190 –> 00:47:02,180
is you can have a look at the statistics.
794
00:47:02,180 –> 00:47:04,720
So for example, the Inside volume,
795
00:47:04,720 –> 00:47:06,970
I can have a look at how many samples here
796
00:47:06,970 –> 00:47:08,353
fall below my cutoff.
797
00:47:09,220 –> 00:47:14,220
So out of the, what’s that, 3465 samples,
798
00:47:15,260 –> 00:47:19,200
260 those are below my cutoff.
799
00:47:19,200 –> 00:47:21,613
So you can kind of work out again,
800
00:47:21,613 –> 00:47:24,100
a very rough dilution factor by dividing
801
00:47:24,100 –> 00:47:27,140
the number of samples that fall inside your volume
802
00:47:28,310 –> 00:47:29,610
by the total number of samples.
803
00:47:29,610 –> 00:47:31,020
Which would bring you out around
804
00:47:31,020 –> 00:47:33,993
in this case for the 0.3 around seven and a half percent.
805
00:47:37,580 –> 00:47:40,610
So it’s just, this exercise is really just to highlight
806
00:47:40,610 –> 00:47:43,162
some of the, again, the tools that aren’t necessarily
807
00:47:43,162 –> 00:47:45,200
used very frequently,
808
00:47:45,200 –> 00:47:48,930
but can give you a really good understanding of your data
809
00:47:48,930 –> 00:47:53,200
and help you to investigate the potential of your deposits
810
00:47:53,200 –> 00:47:58,200
by using some of the settings in the Indicator interpolants.
811
00:47:58,669 –> 00:48:02,620
But ultimately coming back to the fundamentals
812
00:48:02,620 –> 00:48:04,870
of building numeric models,
813
00:48:04,870 –> 00:48:08,530
and that is to understand the type of interpolant you use
814
00:48:08,530 –> 00:48:11,750
and how that Drift function can affect your models
815
00:48:11,750 –> 00:48:13,100
as you move away from data.
816
00:48:15,160 –> 00:48:18,822
So that’s probably a lot of content for you
817
00:48:18,822 –> 00:48:23,500
to listen to in the space of an hour. As always,
818
00:48:23,500 –> 00:48:26,680
we really appreciate your attendance and your time.
819
00:48:26,680 –> 00:48:28,580
We’ve also just popped up on the screen,
820
00:48:28,580 –> 00:48:33,580
a number of different sources of training and information.
821
00:48:33,810 –> 00:48:35,347
So if you want to go
822
00:48:35,347 –> 00:48:38,440
and have a look at some more detailed workflows,
823
00:48:38,440 –> 00:48:41,980
then I strongly recommend you look at the Seequent website
824
00:48:41,980 –> 00:48:43,500
or our YouTube channels.
825
00:48:43,500 –> 00:48:45,930
And also in the, MySeequent page,
826
00:48:45,930 –> 00:48:47,860
we now have all of the online content
827
00:48:47,860 –> 00:48:50,110
and learning available there.
828
00:48:50,110 –> 00:48:52,660
As always we’re available through the Support requests.
829
00:48:52,660 –> 00:48:54,057
So drop us an email
830
00:48:54,057 –> 00:48:57,820
and if you want to get into some more detailed workflows
831
00:48:57,820 –> 00:49:01,830
and how that can benefit your operations and your sites,
832
00:49:01,830 –> 00:49:03,570
then let us know as well.
833
00:49:03,570 –> 00:49:05,420
We’re always happy to support
834
00:49:05,420 –> 00:49:08,900
via project assistance and training.
835
00:49:08,900 –> 00:49:13,290
So that pretty much brings us to the end of the session,
836
00:49:13,290 –> 00:49:14,480
to the top of the hour as well.
837
00:49:14,480 –> 00:49:17,780
So again, thanks to you for attending,
838
00:49:17,780 –> 00:49:21,940
thanks to Suzanna and Andre for putting this together
839
00:49:21,940 –> 00:49:23,500
and running the session.
840
00:49:23,500 –> 00:49:25,700
And we’ll look to put another one
841
00:49:25,700 –> 00:49:27,690
of these together again in the new year.
842
00:49:27,690 –> 00:49:29,540
So hopefully we’ll see you all there.
843
00:49:30,630 –> 00:49:33,463
Thanks everybody and have a good day.
