Objective:
I would like to set my colour legend bar transparent without getting the text transparent in Oasis montaj.
Resolution:
At this moment, there is no way to do it automatically. However, there is a workaround.
Please do the following:
1. Lelft-click your colour legend bar in the map > right-click > copy > right-click again > paste Georeferenced.
2. It should show two colour legend bar in your Base in Map Layers Tab
3. In the Base Tree, click on the copied one (_2) > the colour legend bar will be selected in the map > right-click > Edit vector group
4. Click on the map > drag and drop a selection box around the colour bar only > once only the colours are selected, click delete. It will seem at first that you deleted both, as it will be blank, but the original colour bar is still there (if you click anywhere in the map you will see the one underneath). You have only deleted the copied one on the top.
5. In the Base Tree, click on the original colour legend bar > set the transparency desired. Your colour legend bar should have transparency applied, and you should be able to see your text without transparency.
Get more Oasis montaj support
More Support
