Objective:
I have a project in Seequent Central I would like to rename.
Resolution:
1. Log into your web portal (e.g. region-companyname.central.seequent.com), and click the Context menu in the top left, followed by “Projects”:
2. After doing so, select the project you would like to rename by left clicking on it. A similar window to the following should display:
3. Once selected, click on the larger title at the top left. You will be able to make your desired changes in this field:
4. Having made your desired changes, press the Enter key to confirm your changes. Your project is now renamed.
Notes:
You can search for a specific project by title by using the search function at the top right of your Projects menu.
