Objective:
I want to import an image as a curved long section.
Resolution:
It is not yet possible to do so within a click, but here is a workaround that might help.
You will first need to create a vertical surface and then use it to drape the image on.
1) Creating a vertical surface (This can be done in two different ways depending on the version you are using).
The first step consists in importing or creating the line your section needs to follow.
Afterward, you create the surface either with a fault creation or with the extrude mesh tool.
Solution a: Creating surface from the new extrude tool
d. Repeat as needed.
Solution b: Creating surface from the fault tool (in version anterior to Leapfrog 2021.2)
d. Repeat as needed
Part 2: Draping images to surface
- Right-click the newly extracted Mesh representing the section you want to import.
- Select Drape Image -> Import and select the desired image.
- Georeference as needed
- Repeat for each mesh section.
Notes:
Some distortion of the images will happen depending on the magnitude of the curve and the number of sections used.
