Objective:
Objective 1: I have my drillholes/boreholes loaded, but I want to determine what the elevation (x,y,z coordinates) is at the bottom of the drillhole.
Objective 2: I also want to know what the real depth is (e.g. vertical depth below topography)
Resolution
Solution Summary:
  1. To obtain X,Y,Z:
    • Backflag an empty Geological Model to create an interval table
    • Export the backflagged table and include Interval End Points
    • Reimport the table as Points
  2. To determine True Depth:
    • Import the Z again as another column in the Points file
    • Set the elevation to Topography
    • Create a calculation of Z on Topo – original Z
Detailed Solution Workflows:
  1. To obtain X,Y,Z:
      • Right click on Geological Models > New Geological Model, and keep the Base Lithology set to None
      • Ensure the extents covers all drillholes
      • Right click on Drillholes > New Evaluation, and choose the empty GM
    • Reimport the table as Points. You only need the X/Y/Z
    • Tada, X Y Z values for the end of hole
    • If you want to add a label for the Z value, you will need to follow the first part of Part 2
    • Import the Z again as another column in the Points file by Right Clicking > Import Column and choose the same file.
    • Make sure to change the data type for Z to Numeric, otherwise you won’t be able to import it
    • Set the elevation of the Points file to Topography by Right Clicking > Set Elevation
    • Create a calculation of Z on Topo – original Z by Right Clicking on the Points > Calculations and Filters.
    • You now have a column that represents true depth. Since this is dynamically linked to your Z value, if you want to move Z back to the EOH elevation you will need to export/reimport to remove the dynamic link.
    • If you export, make sure to tick INCLUDE CALCULATIONS within the export.
Please contact [email protected] for any questions with this workaround.
Get more product support
More Support
