Objective:
I need to share / export my holes as 3D objects (solids) with other software. Like a cylinder around each interval.
Resolution:
You can create a combined model from a distance function and geological model to create an approximation of this. The final shapes will be created with the geological model contacts in mind so they will most likely not be perpendicular to the hole.
In addition some cleaning might be required.
This assumes that a geological model has been created.
1. Create a DISTANCE FUNCTION in the Numerical Models folder
2. Set the objects needed, interval table or traces generally. Add a query filter if needed.
3. Set the distance buffer to the radius your require. Ex 8
4. Create a NEW COMBINED MODEL in the Combined Models folder.
5. Combine the DISTANCE FUNCTION and the GEOLOGICAL MODEL
6. Export the Result
Get more product support
More Support
