Objective:
I need to colour my output volume by thickness.
Resolution:
Currently only the Vein surface allows for direct thickness colouration. This is a workaround to apply a approximate thickness for any surface.
In the example below we’ll be using Leapfrog Geo, but it will work with any Leapfrog version.
- Take your surface and extract the Thickness grid with an appropriate spacing (10×10 in this example).
- Import the grid as 2D grids (in Geophysics folder), you can now access the numerical data of the thickness grid (Band 1)
- Set elevation on the grid to your surface / topography (in this example the topography was used)
- Run a RBF Interpolant with the grid values and inside the original volume.
- Change the RBF Interpolant settings;
- Remove the Output volumes (you don’t need the volumes to be created)
- Change the Range to basically your grid spacing (avoids to much smoothing), your settings may vary.
- Depending on the geometry of the surface the trend may also need to be adjusted.
- Evaluate on the Original Volume.
Resulting example with 2D grid as points and evaluated output volume:
Example as block model blocks:
Notes:
- This works best on volumes that are not overlapping in any way.
- This can also be done partly using Sub Block Models with variable Z height, depending on the orientation. It is also depending on the calculations and filters being active on the license.
- or as an export to input in the above workflow.
