Dataforensics unlocked incredible value for the US Army Corps of Engineers by moving subsurface data to the cloud, saving years in migration time and 62,700 work hours along the way.
By Paul Colbert
For decades, the US Army Corps of Engineers (USACE) has been gathering subsurface data essential to its operations – literally millions of linear feet of it, for thousands of projects, including dams, levees, buildings, bridges and more, scattered around the world.
Unfortunately, the number of databases in which this critical information resided was of a similar scale.
Listen to Scott Deaton President of Dataforensics as he discusses how the team successfully navigate the project’s unique accessibility, collaboration and interoperability challenges, to unlock a data asset worth more than USD $500 million.
The USACE had accumulated more than 500 separate and disparate database structures, leading to increasing issues with accessibility, collaboration, interoperability and workflow.
As the problems and resulting inefficiencies mounted, USACE made the strategic decision to introduce a global standardisation for its subsurface geotechnical data management and put OpenGround at the heart of its cloud-based enterprise data management.
The top priority was to compile and migrate all existing historical subsurface data, which encompassed borehole, laboratory testing, and in-situ testing. To say this was a huge undertaking would be putting it mildly.
Before the data could be loaded into OpenGround, it would first need to be cleaned and standardised, and that’s where the magnitude of the exercise became apparent. To do the job by hand would have likely taken years, if not decades. Geotechnical data management company Dataforensics were therefore recruited to develop a software programme that would automate as much of the process as possible, using the APIs for gINT (where much of the historic data resided) and OpenGround.
USACE map of the existing projects, approximately: 8500 projects, 200,000 locations and more than 8 million feet of drilling.
2 years
Data migration done in 2 years, 20 times faster than manual estimates.
$500M
ROI: Spend of $500k transformed USACE data into a $500m asset.
62,700
number of hours saved by going digital.
Apart from giving USACE vastly improved access to its data, and the ability to extract greater value from it, the shift to OpenGround enhanced operations in a number of other ways, such as improved collaboration between offices and contractors.
Going digital allowed USACE to unlock a tremendous asset and improve the quality of their subsurface data.
Interoperability was improved, with data now more easily integrated into software such as Civil3D, Leapfrog Works, GeoStudio and GIS platforms. In particular, the ability to import borehole information into the same platform as geophysical data (in Leapfrog) and a variety of other data (in GIS) greatly improved workflows and the ability to visualise data sets together.
Red Rock Dam project site using modern data collection methods displayed Leapfrog Works and OpenGround.
The data includes geology, geographic, and geophysics data, for a comprehensive understanding of the site to address seepage concerns and design appropriate solutions.
Bringing every district under the single roof of a standardised database structure
USACE had been primarily using gINT software to manage their borehole data. However, there was no standard in place and each of the district offices was managing their information on separate servers with their own formats and reports.
Shifting to an enterprise level cloud solution allowed USACE to implement a standard database structure across all districts and projects.
Hunting for anomalies and correcting typos
To improve the quality of the data, Dataforensics addressed several issues. This included correcting typographical mistakes in date values, fixing data types in scenarios where numeric values were stored in text fields in gINT, and ultimately standardising vast quantities of gINT data. Additionally, there were numerous soil properties from lab test results such as soil classifications, or interpreted results from particle size distribution tests, which were shown on gINT reports, but not actually stored as data in the database.
Related articles
Using OpenGround with North American Government Contracts
In this video, you will learn where OpenGround fits into the transformation the industry is ...
How Leapfrog Works helped understand and communicate ground conditions for the proposed Crossrail 2 railway
Major infrastructure projects need an ongoing understanding of ground and ground water conditions to hone ...
GeoStudio Integration Workflow
1. Analyse slope stability using piezometric lines with SLOPE/W Use SLOPE/W to do a simple ...
The successful seven-step solution was:
  • 1. Organise the files into similar database structures that could all be migrated at the same time.
  • 2. Generate PDF log reports for each gINT project using the gINT API.
  • 3. Setup a data cleanup/conversion template for each set of similar database structures.
  • 4. Perform calculations that are often reported in gINT but do not exist in the gINT database.
  • 5. Convert to an OpenGround compatible data format.
  • 6. Upload data to OpenGround using the OpenGround API having automatically identified the coordinate system.
  • 7. Upload PDF documents of gINT logs to OpenGround using the OpenGround API.
All but step 3 – which required a geotechnical data specialist competent in gINT and OpenGround – were run autonomously with human oversight to check each step had been completed successfully. Left to a human without autonomous support, Dataforensics calculated that it would have taken 20 times as many hours to reach the end of the task, a saving of 67,000 hours in total.
The spillway of the Lower Granite Lake Dam on the Snake River in Washington, USA
The US Army Corp of Engineers had subsurface data from thousands of projects including dams, levees, bridges and more.
Moving on from ‘how we’ve always done it’
Going digital and having all subsurface data in a single enterprise database (OpenGround), has helped USACE unlock the true value of a powerful asset.
The improvements in efficiency of personnel using a standardised geotechnical data management system, plus the associated cost and time savings, are substantial. USACE can collaborate more effectively across the supply chain, which saves work hours and increases productivity.
Having this information easily available in OpenGround means teams can more quickly leverage historical data to reduce risk in ongoing projects, and lessen carbon footprint by avoided re-drilling boreholes at the same locations.
USACE must also deal with critical geotechnical and geological questions that require rapid answers. The ease with which OpenGround allows the access and sharing of information has accelerated the USACE’s responses (for example, once giving within minutes the advice the Air Force required about boreholes near an area they were operating).
Standardised data from contractors means that USACE now gets all the data required for contractors to complete their investigation projects so the datasets they are receiving are more complete (e.g. they include boreholes, lab testing and in-situ testing data), available in a format they can reuse, and extract additional value from in the future.
OpenGround is speeding up the way teams can utilise data in other systems such as AutoCAD Civil 3D, Leapfrog, GeoStudio, PLAXIS, and Excel which means subsurface conditions on their sites can be evaluated more quickly, and robustly with data driven decisions made more confidently, accurately and rapidly.
Moving USACE from a paper-based to a digital agency was a complex task, but one that has left the organisation infinitely better prepared for its future.
The USACE owns and/or maintains more than:
  • 700 dams
  • 2000 levee systems
  • 236 navigation lock chambers
  • 25,000 miles of navigable waterways
Plus a range of military and environmental programs and missions that incorporate structures with life-saving implications.
With a staff of 37,000 military and civilian personnel, the USACE is one of the world’s largest public engineering, design and construction agencies.
Dataforensics was a 2024 finalist in Bentley’s prestigious Going Digital Awards in Infrastructure, in the Subsurface and Modelling category.
Learn more about our geotechnical solutions
