Welcome to Target for ArcGIS Pro, to start, you need to complete a few simple steps.
Create your Seequent ID
Your Seequent ID is your business email address that is registered with Seequent. Your Seequent ID (email+password) gives you secure access to your Target for ArcGIS Pro subscription, Seequent Central, online services (such as this training), and support resources. A Seequent ID with an active subscription is required to run Seequent applications installed on your computer.
If you already have a Seequent ID, you can sign into Target for ArcGIS Pro.
If you do not have a Seequent ID, please create one here.
Download Target for ArcGIS Pro
Once you have created your Seequent ID, you can download Target for ArcGIS Pro from MySeequent. MySeequent is the home for software downloads, learning, training and support. Simply login with your Seequent ID here and find the download button.
Opening Target
Target for ArcGIS Pro can be opened from the Start menu.
To Start:
  1. On the Start menu, select All Programs, then select Target for ArcGIS Pro.
  2. ArcGIS Pro opens with the default Project window. This window enables you to Create a new project, Open a previously created project, or Open a recent project.
3. Click Map to open the New Project
4. Locate your project folder (the folder that contains all your current project data). Specify a name for your project and click OK.
Your new project is created and the ArcGIS Pro workspace displays the Target ribbon, Seequent Sign In and Help.
We recommend all new users familiarise themselves with our online learning path before creating their first project.
Get more support for Target for ArcGIS
More Support
