Welcome to Central
To start, you need to complete a few simple steps.
Create your Seequent ID
You will need to use your Seequent ID to access Seequent Central.
If you already have a Seequent ID or you are using a Bentley account, you can move on to connecting to Central.
If you don’t have a Seequent ID, please create one here.
Accessing Central in your Web Browser
In your welcome email, select the open portal link to navigate to the Central Portal and sign in with your Seequent ID.
To connect to Central from our desktop applications see the steps below.
Connecting to Central from Leapfrog
Leapfrog allows you to publish projects to Central. If you are a Leapfrog user, please complete this additional step.
- Download and install the latest version of Leapfrog Geo, Leapfrog Works or Leapfrog Energy.
- Open Leapfrog and under the connection setting select use Seequent ID.
- Restart the application and ensure you are signed in at the top right of your screen.
- To connect to a specific server, click on the Central Projects tab and select the server you want to connect to. If you can’t see your server on the list, click the Refresh button or try signing out and in again.
For help connecting Leapfrog to Seequent Central read the step by step instructions or watch this video.
If you would like assistance with this set up process, please contact your local Seequent team.
Connecting to Central from Oasis montaj
- Sign into Oasis montaj with your Seequent ID as normal.
- Seequent Central connects with your Seequent ID to determine which Central servers you have access to. You can check your server availability by selecting the cloud icon in the top right corner.
- The cloud icon will be green when you are connected to Central.
- Once a server is connected, the Central Datastore workflow will be active in Oasis montaj.
Read the step by step instructions on how to connect and how 2D Geosoft grids can be loaded directly in Leapfrog from the Central Dataroom.
Learn how to use Central
We have a number of videos and other online resources, available through MySeequent that can help you get started with Central in no time.
