This webinar introduces a new and modern workflow for 3D data integration using a Play Fairway Analysis approach, using various sub-surface datasets from geology to geophysics and well data. You will learn how to combine data sets into a single calculated model that highlights the most promising areas for drilling.
This webinar introduces a new and modern workflow for 3D data integration using a Play Fairway Analysis (PFA) approach. While PFA is used in the hydrocarbon industry regularly to mitigate exploration risk from regional to prospect scale, it is only recently being applied to geothermal examples around the world.
We will take you through using various sub-surface datasets from geology to geophysics and well data, to combine them into a single calculated model that highlights the most promising areas for drilling.
While this is a technical webinar and the technical aspect is advanced, you do not not require any prior knowledge of Leapfrog Energy or Edge (our add on geostatistical tool). A background in geothermal resource exploration and concepts of geomodelling will be useful to take the most away.
Overview
Speakers
Clare Baxter,
Customer Solutions Specialist – Energy
Andrew McMahon,
Regional Segment Manager – Energy
Bastien Poux,
Director Aetna Geothermal
1 hour 30 minutes
Find out more about Seequent's energy solution
