Understand Imago in 15 minutes. Join us for this short webinar where you will see how Imago is the only solution that covers the whole process of gathering and using geological images - from capture to cataloguing, analysis and sharing!
Capturing, saving and accessing images of drill core/chips is essential – but the current processes need improvement!
The industry has developed its own way of capturing images of drill core/chips, saving them securely, and accessing them for later use. However, the industry standard is often built around software, technology and processes that aren’t specifically built for geological images – which makes every part of the process slow, frustrating, and prone to human error.
We know you are busy, so in just 15 minutes Seequent Technical Experts will explain the key features of Imago, an end-to-end solution that makes every stage of the process smoother – from capturing to naming, syncing and integrating image data into downstream workflows:
• Capturing images
• Cataloguing and accessing images
• Storing images
• Taking replacement images
• Visualisation
• Integration with 3D geological models.
Overview
Speakers
Sophie Tie and Richard Millington
11 minutes
