Workbench Views
topographic vector
Workbench Views is a flexible, visual tool for efficient processing and visualisation of all EM and streamed ERT data. Customizable settings available in specialised “views” enable you to tailor your visualisation to your workflow needs. With these views, you can create, save, modify, and synch data visualisations.
Key features
  • Data, models, and plot settings are automatically saved to a View
  • Open a saved View and automatically load saved settings
  • Save plot settings and apply them to an alternate View
  • Export plots to separated or combined bitmaps
Buffer control
Control the data and model displays with two buffer options:
  1. Time or distance buffer shifts the displays to the next selected buffer interval.
  2. The line number buffer advances the display to the next line.
With multiple open Views, you can easily shift between data and model displays and you can sync plots within each View; when the buffer is used on one plot, the other plot will follow, and the x-axis will be aligned.
Customisation and synchronisation
Each data, model, sounding, and auxiliary plot has its own settings, making it easy to personalise each plot and view. Customise your views by:
  • Changing display units
  • Changing displayed data
  • Editing colour scales
  • Adding QC parameters to model plots
  • Interpolating models
  • And much more
The integration with the Workbench GIS interface allows for the mouse position on a plot to be simultaneously displayed on the GIS. This feature streamlines the process of pinpointing the exact geographical locations of data or models. It also enhances data processing by enabling the effective utilization of GIS maps for contextual reference and analysis.
Vista de datos
La vista de datos es ideal para el procesamiento manual y admite hasta cuatro gráficos simultáneos. La configuración predeterminada contiene dos gráficos que muestran datos sin procesar y datos promedio, cada uno con un gráfico de sondeo correspondiente que muestra las mediciones seleccionadas. Al procesar en cualquiera de los dos tipos de gráfico, puede seleccionar datos, deshabilitarlos o asignarles un error mayor. En la vista también se encuentra un gráfico auxiliar que muestra los parámetros del instrumento, como la elevación, la velocidad, la corriente y la información del GPS. Este gráfico también se puede utilizar para editar la altitud de los datos.
Vista de datos/modelo
La vista de datos/modelo se utiliza para visualizar los resultados del modelo a partir de inversiones y consta de gráficos de datos con sus correspondientes gráficos de sondeo y auxiliares, como la vista de datos. Un gráfico adicional muestra modelos de inversión sincronizados con gráficos de datos para facilitar las referencias cruzadas.
Cuando selecciona un modelo, puede abrir una vista de modelo de línea o puede usar la vista de parámetros de modelo para abrir una lista de todos los parámetros resultantes para todos los modelos. La vista de datos/modelo facilita el reprocesamiento de los datos al proporcionar una visualización de los resultados y su ajuste, lo que le permite identificar los datos correspondientes que deben modificarse para una nueva inversión.
Vista de modelo
La vista de modelo se usa para comparar los resultados de diferentes estudios, tipos de datos o resultados de modelos creados a partir de los mismos datos. Esta vista puede contener hasta cuatro gráficos, y cada uno puede mostrar nuevos modelos.
Vista auxiliar
La vista auxiliar se utiliza para trazar datos auxiliares adicionales disponibles de los instrumentos. Con esta vista se pueden trazar, entre otros, la temperatura, la topografía, la corriente, la inclinación y la altitud editada manualmente, lo que permite tener una visión general para los informes finales.
Obtenga más información sobre Workbench
Solicite una demostración
