Are you looking for a more efficient and effective way to conduct your Advanced Geophysical Classification (AGC) surveys?
Look no further than the latest release of Seequent’s Oasis montaj UX-Analyze, which now supports a new dynamic classification workflow. This innovative technology is becoming increasingly popular among AGC sensor manufacturers. It allows you to eliminate the need for a separate static survey, typically used to classify targets as “targets of interest” or non-targets. With support for accredited one-pass classification sensors, you can now run the familiar Classify and Rank tool within the dynamic data workflow. This saves you time and money and allows for a more efficient and streamlined AGC survey process.
Accessing ACG Dynamic Classification and the Classify and Rank tool in Oasis montaj 2022.2
The Classify and Rank bundle has been adapted to run on dynamic data, producing a ranked source database through multiple dipole inversion, library matching, and the ability to set thresholds and prioritise. The tool also produces an interactive image viewer, linking multiple images to sources within your database. This allows you to easily view and analyse polarisation plots, size and decay space plots, planar and cross-section views of Tx-Rx coils with associated sources, and classification plots in one convenient location.
UX-Analyze interactive image viewer in Oasis montaj 2022.2UX-Analyze interactive image viewer in Oasis montaj 2022.2
Additionally, UX-Analyze now supports the latest format of HDF files, HDF v1, specifically from NovaTEM’s TEMSense. This means that you can easily process and interpret your HDF v1 AGC data with additional sensor support for HDF v1 to come. This feature is a huge step forward in the field of AGC, and it makes the data processing and interpretation process even easier for the user.
HDF v1 support in UX-Analyze Oasis montaj 2022.2HDF v1 support in UX-Analyze Oasis montaj 2022.2
In conclusion, the latest release of Seequent’s Oasis montaj UX-Analyze is a game-changer for Advanced Geophysical Classification. Its new dynamic classification workflow and support for the latest HDF format are major advancements that will save you time and money and make your AGC survey process more efficient. Upgrade now and see the difference it can make for your AGC surveys.
Not using Oasis montaj yet?
Download now
