Software DownloadsBrowse downloads by product
To check if your computer meets minimum specs, and find out our recommended options, read our system requirements.
Viewers
Geosoft Viewer
Easily view and share your geoscience data visualisations, for free.
Download
Leapfrog Viewer
A free desktop application, anyone can view scene files exported from Leapfrog modelling products.
Download
Applications
Applications require an active subscription and Seequent ID to be used.
Leapfrog
Leapfrog Geo
Integrate, communicate, and interpret geoscience data with rapid 3D modelling.
Download
Leapfrog Works
Communicate insights with dynamic 3D modelling designed for civil & environmental projects.
Download
Leapfrog Energy
Make clear and confident decisions for energy development and operations.
Download
Leapfrog Edge
Fully integrate resource estimation into your 3D geoscience models.
For GeoFor Energy
Geosoft
Oasis montaj
Visualise, analyse, and integrate all your geoscience data in interactive 2D and 3D models.
Download
Target
Visualise, QA/QC, and share drillhole and geoscience data.
Download
Target for ArcGIS Pro
Advance your understanding of drillhole and subsurface data within Esri ArcGIS Pro.
Download
GEOSLOPE
GeoStudio
Model slope stability, ground deformation, and heat and mass transfer in soil and rock.
Download
AGS
Res2DInv
Easily process and invert your 2D resistivity and induced polarization data for quick and accurate insights.
Download
Res3DInv
Easily process and invert your 3D resistivity and induced polarization data for quick and accurate insights.
Download
Workbench
Tailor and refine every step of your EM, ERT, or IP workflow from raw data to final geophysical models, and present results confidently.
Download
SPIA
TEM and DC/IPVES data processing and inversion.
Download
Data Management
Seequent Central
Manage, track, and collaborate on geological data in a single, accessible environment.
Download
DAP Data Management
Ensure your geoscience data is of the highest quality – in one single, accessible source.
Download
Geothermal Simulation
Volsung
The standard for geothermal reservoir simulation.
Download
Plug-ins & Utilities
A troubleshooting tool that gathers information about your computer and any GEOSLOPE products installed on it.
All you need to run a FlexNet™ Publisher License Server Manager (“lmadmin”) for use with network (floating) licenses that will work with any version of GeoStudio.
Plug-in to view and use Geosoft grids, shaded grids, and map files in MapInfo.
For use with all GeoStudio USB hardware keys on all versions of Windows.
Developer Tools
The GeoStudio Add-In Developer’s Kit (SDK) includes instructions, templates and sample code to let you write your own Add-Ins.
Developer resources to extend Geosoft platforms and use the GX API in your own applications.
